Problem with monitors - Saphire Radeon HD 6970
Hi everyone,
Got a little problem on my hands here and need some help.
I have three monitors that i want to be active at the same time;
-Acer 19 inch plug by DVI
-DELL 24inch plug by VGA
-Sharp Aquos 41 inch plug by HDMI
I can only have two of them plug at the same time.... how can i get them all extended at the same time?
Thank in advance!
Thank in advance!
You need to plug at least one of them in via DisplayPort for three or more monitor support.
Also, your 6970 doesn't have VGA.
You need to connect at least one of the monitors via an active DisplayPort adapter. Here is the list of adapters approved by AMD. Remember, that is ABSOLUTELY HAS TO BE an active adapter, and yes, it will be more expensive.
If I didn't link to the right card up there, perhaps you can set me up with a picture or link to newegg/sapphire website.
