cpu-z not matching memory advertised speed... Need help with bios settings
I have 4x8gb ram Corsair CMZ8GX3M1A1600C10 and CPU-Z shows PC3-12800j(800 MHz) when it should be 1600.
I've only just now realised that I need to tell the pc what kind of ram I have and I have no idea how to set up XMP, frequency, timings or voltage. I have I7 cpu and Gigabyte Z68X-UD3H-B3 motherboard.
PLEASE HELP!
PLEASE HELP!
Firstly 4x 8gb of same
http://www.facebook.com/photo.php?fbid=10151560001005031&set=a.10151560000940031.603071.670905030&type=3&theater
http://www.facebook.com/photo.php?fbid=10151560001270031&set=a.10151560000940031.603071.670905030&type=3&theater
and now with 2x4gb + 2x8gb (my old setup that works)
http://www.facebook.com/photo.php?fbid=10151560001885031&set=a.10151560000940031.603071.670905030&type=3&theater
http://www.facebook.com/photo.php?fbid=10151560002315031&set=a.10151560000940031.603071.670905030&type=3&theater
Hope this helps
800MHz = DDR3-1600 = PC3-12800.
Your second set of screenshots shows your RAM running at DDR3-667 speeds, which would indicate that all of the RAM is running at the speed of the slowest module(s). If that's not the case, enter the PC BIOS and manually set the clocks to DDR3-1600 speeds and use the timings labelled on the memory sticks,.
To enable XMP memory profile:
-Open BIOS settings at boot (DEL)
-Load Optimized Defaults to confirm a "normal" setup
-Change any boot order SATA settings or other settings you know need to be changed
-Go to "MB Intelligent Tweaker"
-Go to "Advanced Memory Settings"
-Choose the XMP option and enable Profile 1
-Hit F10 to save and exit
Be specific about "running so poorly"
so i did a memory check on all 8gb sticks and no errors were reported
What memory check did you try?
I did that windows memory check that runs when pressing tab during loading
will try to update bios after that
tnx for the help
