Wall mount PC case design
Hi all, long time no chat
It's about upgrade time again and one thing I must upgrade is my PC case. Between old water cooling modding holes, 4 children, and other mods my old knock off Antec case has about had it. There are plenty of great cases out there but with my children's ability to hit the rest button, limited floor space, and pure hatread of desktop cases, I've pretty much been reduced to making my own.
The plan is to buy a donor case for the motherboard tray, hard drive bays, power button and whatever else I may need and with my wood working skills build a wall-mount-case.
My biggest concern is heat. I do overclock. The case will be drawing air from the bottom and exhausting at the top. Please view the sketch-up pictures I've attached to get an idea what I'm looking at. The 80mm fan usually found on the rear of a traditional case will be one of my intakes. As you can see this case will be mounted right above my 24inch lcd. It'll be about 6 inches above it. And while the heat isn't great I wanted to get your ideas on it.
Space is limited as you can see. My daughters use that little table on the side for homework and a breakfast nook.
Also if you take a look at the exhaust for the power supply, it'll be feeding into a chimney type hole to conceal the back of the tower and its wires. I don't think it'll get too hot in that chimney or build up too much to effect the rear intake that'll be blowing towards the CPU and the top of the video card.
At least I'll get to buy some new power tools! yay
I think I'd partition the chimney into upper and lower halves, just to be safe.
Anyways, I eyeballed it in the store and got lucky. Looks like I'll get all the pieces I want out of it. Pictures below.
If anyone has an old case they are looking to sell or especially a mother board tray, let me know. I have paypal
I should have another update coming this weekend, as long as it doesn't rain.
Just a thought.
Good looking out Muddoctor. I really wanted to make my own motherboard tray but I didn't want to deal with the hassle of dealing with all the IO stuff.
I'm thinking about this one. http://www.mountainmods.com/modular-io-panel-brushed-alu-p-486.html
Thanks again man.
I saw those too. At first I was like ohh yeahh.. but I want to have at least four hard drives and those only fit a max of 3. I think I'll just end up making some brackets and attach the hard drives in a way that the intake air is sandwiched b tween them. But I liked the idea of using the fan screw as a mount so I'll be following their lead in that regards.
Does anyone know if it is more important for the metal side (silver part) of a hard drive to get air or the side with the exposed electronics?
Man that was fast. Thanks!
http://upload.wikimedia.org/wikipedia/commons/3/3b/HardDiskAnatomy.jpg
Keeping the spindle motor cool is what you're after. After seeing how it mounts, it makes me think keeping the drive's chassis cooled is what your ultimate aim should be.
Long story short, I talked the employee in the tool world section into selling me the floor model for 20 bucks! They were on clearance for $84 and change. My next project is building a CNC machine and I needed a scroll saw to make accurate cuts. Feel like I won the lottery.
I should be able to cut out all my fan holes, windows, and whatever else with this thing.
A year ago I rebuilt the engine on my 240sx. Well Friday, one of the radiator hoses sprung a leak. I remember when I was attaching that hose seeing a tiny nick and thinking I'll need to replace that hose soon. So tomorrow I'll be doing that and not working on my wall case But luckily I work for the state and we have election day off. So I should be able to put up some pictures of all the boards cut on tuesday. I'm hoping next weekend to actually get a dry assembly going.
PS here's a picture of my scroll saw and my little helper. Before you ask, he's a boy... One of these days I'm going to take some clippers to that boys hair when his mother is not around.
I think so too I just had to make some modifications to it. The top arm was hitting the plastic cover on the up stroke. Nothing a few dremil cut couldn't handle. Now it's almost as smooth as a sewing machine. Tested it on a board and it was a nice straight clean cut. Only thing left to do on it is to drill some holes and make a guide on it. Later on down the road it'll be donating it's led light and blower to the CNC build.
Komete, if you are going to wall mount the case, start thinking about noise and vibration. It has the possibility to radiate vibrations throughout the wall, creating a large snare drum effect! A 25-cent solution would be a patch of carpet padding between the case and the wall. A flooring company would probably give some scrap for free.
That's a good suggestion Leonardo. I was going to glue rubber feet between the wall and the case but padding may work better. I may try both. I have some padding left over from when I redid my stairs. My first job at 14 was installing carpet with my stepfather. I always have some carpet and padding scraps around from odd jobs for family.
The only real problem I'm facing now is how I'm going to secure the boards together. I'm using 1/4 inch birch plywood and I don't want to use nails or screws from anywhere that can be seen. That leaves me the back and the chimney area. I have a few solutions but not one that I'm sold completely on. I think it'll be hybrid of securing techniques.
The design lost about half an inch in depth due to previous bad cuts. Now it has a depth of 7 1/ 2inches. Looks like that'll change my cpu cooler from a side to side version to one that blows down on the chip set.
The scroll saw has proved its worth today. I used a medium blade on it and it still produced clean cuts. Cutting out the fan holes were easy as could be. I simply drilled a hole, ran the blade through, and then let her rip. I'll never cutout another fan hole by hand again. I'm tempted to carve out a unique design with a plexi glass back instead of just a window. The scroll saw is just that nimble. If you can trace a picture, you can do some nice cuts on it.
Only bad thing to report is some of the boards warped slightly from being left standing at an angle for a week. I've pulled out some old weights, those 55's never felt heavier, and hopefully that will flatten that warping out. If anyone has any ideas on how to flatten them again please let me know.
Plans for this weekend:
do a light finnish to protect if from humidity and any future warping
build the HDD cage
build the cdrom cage
Cut down that final board
Possibly start the case assembly.
I still need to cut out a window, the IO ports, one more case fan, cdrom hole, and power button hole. I'm thinking I have about 3 more weeks. It could all be finnished in a weekend, if I pushed, but family comes first.
