Problem with 64bit drivers for realtek 8110s
edited May 2004 in Nerdery
Has anyone had a problem with the drivers for realtek 8110s
I'm getting an error
"Driver not intented for platform"
anyone else have this problem at all.
if anyone has a work around for me or another set i could try that would be great
Neo-FIS2R
AMD 3200+ 64bit
200 GIGs on SATA
Sound Blaster Audigy 2 ZS
Windows XP 64 bit
Windows XP PRO
Worken on Linux/BSD
    edited May 2004
    I gather from your setup information that you can dual boot either XP or XP 64-bit release candidate. When you tried to install the Realtek drivers, were by any chance booted into WinXP 32-bit OS? That would explain the system rejecting the drivers. Your 64-bit Athlon doesn't care about the drivers, but your OS definitely does.
  • edited May 2004
    nope its definitly windows XP 64 i retryed it just before i posted to make sure i didnt look like a moron hehe :)
    the Windows XP 64bit edtion version 2003 is at the botton of my desktop
    and its installed on my first drive and thats what i booted too.
    edited May 2004
    As I have no experience with 64-bit anything, my only comment now is that perhaps the drivers aren't really ready for action. Sorry I can't be more helpful.
  • edited May 2004
    what exact drivers are you trying to install for realtek.
  • deicistdeicist Manchester, UK
    edited May 2004
    I'm using the MSI Neo board, and the best drivers I've found (well, the only ones that work) are here:
    ftp://152.104.125.40/cn/nic/rtl8169rtl8169sbrtl8110sb/amd64-8169(105).zip
    from the realtek website. If the direct link doesn't work, go here:
    http://www.realtek.com.tw/downloads/downloads1-3.aspx?keyword=64
    About half way down you'll see "RTL8169/RTL8169S(B)/RTL8110S(B)" and a link for AMD64 drivers.
    Hope all that helps.
    edit: hmmm, why doesn't the forum parser pick up ftp links as links?
  • edited May 2004
    That driver is in the XP 64-bit install.
    When you go to update the driver, choose the options that allow you to choose for yourself. When you get to the window w/all the developers in the left pane, scroll to find Realtek (BTW there are 2 Realtek entries).
    with the MSI Neo FIS2R, use the one that says "Gigabit" in the driver selection.
    Thats how I got mine working. no need ot download drivers.
  • edited May 2004
    yup that works thanks alot Augie64.
    The drivers provided on the XP 64 disc worked.
    Thanks everyone that posted.
    No its just a matter of finding the right linux distro and the drivers now thats the real challange :)
  • edited May 2004
    egads..... linux drivers. if you find anything worth while please post. I wont even atemp linux untill ati gets ome drivers.
