Help!!!
edited June 2004 in Hardware
Hi, I have a question, when I am on the internet for like 1 hour or more, the window just closes, and when I am working in some 3d programs they sometimes close or won't work, and I was wondering what I can do to fix this, I have a Dell Dimension 2350, with Windows xp, it is an 80GB hard drive and I have only used 42 GB, every week or so I get a notice on my tray where the time is that says windows virtual memory is low some tasks may be denied, what can I do to get more virtual memory, and if it isn't a peripheral how do I install it? TIA
  • TheBaronTheBaron Austin, TX
    edited June 2004
    i think you're getting hard disk space confused with memory. if i had to guess, your problem is that you dont have enough ram, and you're overusing your page file (virtual memory). im looking up what type of ram you need right now
    /edit/ alright i looked it up and this thing comes stock with 256mb of ddr266, otherwise known as pc2100. it doesnt seem to me that just web browsing should be using up all of that ram though, so will you go ahead and post a hijackthis log, just for kicks?
  • JustinJustin Atlanta
    edited June 2004
    http://www.spychecker.com/program/hijackthis.html
    Download the file found at this site and run the program. It will bring up a list of things that are runnign on your PC that you probably have no idea about. Post the findings here and we can tell you what to do next. Adding RAM is always a good idea but we may be able to increase you page file size to meet your needs. You came to the right place though! :)
    edited June 2004
    americandreams63
    First question: Can you confirm the amount of physical memory you have? Click START and then RIGHT CLICK on MY COMPUTER and choose properties. It'll be there on the SYSTEM PROPERTIES - GENERAL tab near the bottom right corner.
    Second: In that system properties display choose the ADVANCED tab and then click on SETTINGS in the PERFORMANCE area. CLICK the ADVANCED button and then click CHANGE in the VIRTUAL MEMORY area near the bottom.
    What does it say in the PAGING FILE SIZE FOR SELECTED DRIVE area. Is the SYSTEM MANGED SIZE radio button enabled and what are the min-max settings?
    256 MB is a bit low for WinXP to be "comfortable" though it will work with 256 MB. 512 MB of ram is preferable. With 3D programs you betchya that 256 MB is a bit low for memory as the page file/virtual memory will be in use. Windows starts to access space on the drive in place of the extra memory it needs and that gets "full" after a while. Even though it's temporary hard drive space in place of RAM...it doesn't always release it for other use...thus the proverbial glass of water...gets full and you get that out of virtual memory error.
    You may want to change the virtual memory settings.
    Click CUSTOM SIZE and type in 512 as both min and max. Choose SET and then OK for all the next screens. The computer will need to be rebooted.
    My biggest recommendation besides that is another stick of 256 MB ram. That will definitely help.
    edited June 2004
    Ditto!
    edited June 2004
    i'd still like to see his hijackthis log
    edited June 2004
    Ditto there too!!!
  • edited June 2004
    Thank You every one for your help, Media Man here are those answers: the system properties window says 128 Mb of RAM, the paging file size says 400 mb but I had changed it to that, and the system managed size button wan't enabled, and the min max was 250/450, but again I changed that., I will do that hijacker thing in a little while, and I will post the results first thing. Thank You Again. Ran Hijack this, here is what it found:
    Logfile of HijackThis v1.97.7
    Scan saved at 2:44:58 PM, on 6/8/2004
    Platform: Windows XP SP1 (WinNT 5.01.2600)
    MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
    Running processes:
    C:\WINDOWS\System32\smss.exe
    C:\WINDOWS\system32\lsass.exe
    C:\Program Files\Common Files\Symantec Shared\ccSetMgr.exe
    C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
    C:\WINDOWS\Explorer.exe
    C:\WINDOWS\system32\cisvc.exe
    C:\WINDOWS\System32\hkcmd.exe
    C:\Program Files\McAfee.com\Agent\mcagent.exe
    C:\Program Files\Corel\Smart Graphics\Server\isf.exe
    C:\Program Files\Roxio\Easy CD Creator 5\DirectCD\DirectCD.exe
    C:\PROGRA~1\mcafee.com\vso\mcvsshld.exe
    C:\Program Files\Common Files\Dell\EUSW\Support.exe
    C:\Program Files\Hewlett-Packard\HP Share-to-Web\hpgs2wnd.exe
    C:\Program Files\Real\RealPlayer\RealPlay.exe
    C:\PROGRA~1\HEWLET~1\HPSHAR~1\hpgs2wnf.exe
    C:\Program Files\Dell\Support\Alert\bin\NotifyAlert.exe
    c:\PROGRA~1\mcafee.com\vso\mcvsrte.exe
    C:\Program Files\Common files\updmgr\updmgr.exe
    C:\Program Files\Common Files\Symantec Shared\ccApp.exe
    C:\Program Files\Norton AntiVirus\navapsvc.exe
    C:\PROGRA~1\FLAWFL~1\ListDownload.exe
    C:\Program Files\Norton AntiVirus\SAVScan.exe
    C:\WINDOWS\System32\rundll32.exe
    C:\WINDOWS\system32\deinst_qfe002.exe
    C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
    C:\WINDOWS\System32\wbem\wmiapsrv.exe
    C:\Program Files\Stop-the-Pop\stopthepop.exe
    C:\WINDOWS\system32\cidaemon.exe
    C:\WINDOWS\System32\wuauclt.exe
    C:\Program Files\AIM95\aim.exe
    C:\Program Files\Internet Explorer\iexplore.exe
    C:\HijackThis.exe
    C:\Program Files\Messenger\msmsgs.exe
    R1 - HKCU\Software\Microsoft\Internet Explorer,SearchURL = http://4-counter.com/?a=2
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Bar = http://look-today.com/searchbar.html
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = res://mshp.dll/sp.html#37049
    R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://look-today.com/passthrough/index.html?http://res://mshp.dll/index.html#37049
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://www.dellnet.com
    R1 - HKCU\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://look-today.com/searchbar.html
    R1 - HKLM\Software\Microsoft\Internet Explorer,SearchURL = http://4-counter.com/?a=2
    R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = res://mshp.dll/index.html#37049
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://look-today.com/searchbar.html
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = res://mshp.dll/sp.html#37049
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = res://mshp.dll/index.html#37049
    R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = res://mshp.dll/sp.html#37049
    R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://look-today.com/searchbar.html
    R1 - HKCU\Software\Microsoft\Internet Explorer\SearchURL,(Default) = http://search.scourweb.net/nph-search.cgi?partner=wesrch1&look=stmpl1&kw=
    R1 - HKCU\Software\Microsoft\Internet Explorer\Main,HomeOldSP = http://searchmyrequest.com/hp.php
    F0 - system.ini: Shell=Explorer.exe C:\WINDOWS\System32\System32.exe
    F2 - REG:system.ini: Shell=Explorer.exe C:\WINDOWS\System32\System32.exe
    O2 - BHO: (no name) - {000020DD-C72E-4113-AF77-DD56626C6C42} - (no file)
    O2 - BHO: (no name) - {00041A26-7033-432C-94C7-6371DE343822} - (no file)
    O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Reader\ActiveX\AcroIEHelper.ocx
    O2 - BHO: (no name) - {2E9CAFF6-30C7-4208-8807-E79D4EC6F806} - C:\Program Files\Submit\submithook.dll
    O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
    O2 - BHO: . - {D34F08C5-4F18-477c-86CB-1A9BEECFE37B} - C:\Documents and Settings\K.C. Daniels\Application Data\windc\windc32.dll
    O2 - BHO: ShowSearch module - {E2DDF680-9905-4dee-8C64-0A5DE7FE133C} - C:\WINDOWS\winvl\mssearch.dll
    O2 - BHO: (no name) - {FD9BC004-8331-4457-B830-4759FF704C22} - C:\WINDOWS\winvl\msiesh.dll
    O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
    O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
    O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\System32\igfxtray.exe
    O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\System32\hkcmd.exe
    O4 - HKLM\..\Run: [MCAgentExe] C:\Program Files\McAfee.com\Agent\mcagent.exe
    O4 - HKLM\..\Run: [MCUpdateExe] C:\PROGRA~1\mcafee.com\agent\McUpdate.exe
    O4 - HKLM\..\Run: [AdaptecDirectCD] "C:\Program Files\Roxio\Easy CD Creator 5\DirectCD\DirectCD.exe"
    O4 - HKLM\..\Run: [VirusScan Online] c:\PROGRA~1\mcafee.com\vso\mcvsshld.exe
    O4 - HKLM\..\Run: [DwlClient] C:\Program Files\Common Files\Dell\EUSW\Support.exe
    O4 - HKLM\..\Run: [Share-to-Web Namespace Daemon] C:\Program Files\Hewlett-Packard\HP Share-to-Web\hpgs2wnd.exe
    O4 - HKLM\..\Run: [/autorun] C:\Program Files\STOPzilla!\/autorun.exe
    O4 - HKLM\..\Run: [SBHC] C:\Program Files\SuperBar\sbhc.exe
    O4 - HKLM\..\Run: [RealTray] C:\Program Files\Real\RealPlayer\RealPlay.exe SYSTEMBOOTHIDEPLAYER
    O4 - HKLM\..\Run: [sr1exe] "C:\Documents and Settings\All Users\Application Data\Dell\Alert\252\updtSup3.exe"
    O4 - HKLM\..\Run: [WindowEnhancer] "C:\Program Files\winex\v9\winex.EXE" /H
    O4 - HKLM\..\Run: [updmgr] C:\Program Files\Common files\updmgr\updmgr.exe
    O4 - HKLM\..\Run: [Norton Antivirus AV] C:\WINDOWS\FVProtect.exe
    O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
    O4 - HKLM\..\Run: [intrabeep] C:\PROGRA~1\FLAWFL~1\ListDownload.exe
    O4 - HKLM\..\Run: [Image] rundll32 C:\WINDOWS\sdkqh32.dll,Install
    O4 - HKLM\..\Run: [vozwv] C:\WINDOWS\vozwv.exe
    O4 - HKLM\..\Run: [New.net Startup] rundll32 C:\PROGRA~1\NEWDOT~1\NEWDOT~1.DLL,NewDotNetStartup -s
    O4 - HKLM\..\Run: [kjod] C:\WINDOWS\kjod.exe
    O4 - HKCU\..\Run: [ssgrate.exe] C:\WINDOWS\System32\system.exe
    O4 - HKCU\..\Run: [Windows Update Checker] C:\WINDOWS\system32\deinst_qfe002.exe
    O4 - HKCU\..\RunServices: [Image] rundll32 C:\WINDOWS\sdkqh32.dll,Install
    O4 - Startup: PowerReg Scheduler.exe
    O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
    O8 - Extra context menu item: Web Savings - file://C:\Program Files\WebSavingsfromEbates\System\Temp\ebateswebsavings_script0.htm
    O9 - Extra button: AIM (HKLM)
    O9 - Extra button: Related (HKLM)
    O9 - Extra 'Tools' menuitem: Show &Related Links (HKLM)
    O9 - Extra button: Real.com (HKLM)
    O10 - Hijacked Internet access by New.Net
    O16 - DPF: {00B71CFB-6864-4346-A978-C0A14556272C} (Checkers Class) - http://messenger.zone.msn.com/binary/msgrchkr.cab
    O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} (Shockwave ActiveX Control) - http://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
    O16 - DPF: {41F17733-B041-4099-A042-B518BB6A408C} - http://a1540.g.akamai.net/7/1540/52/20021205/qtinstall.info.apple.com/borris/us/win/QuickTimeInstaller.exe
    O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - http://messenger.zone.msn.com/binary/MessengerStatsClient.cab
    O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
    O16 - DPF: {F7DC2A2E-FC34-11D3-B1D9-00A0C99B41BB} (Zoom Class) - http://www.zoomify.com/download/zoomify305.cab
    edited June 2004
    Well.
    128 MB of RAM. A wwwwwwweeeeeeeeeeeeeeee bit low don't you think?
    Short-Media Rule #1. You can never have enough ram. I would definitely recommend getting 2 x 256 MB of RAM...better yet...2 x 512 MB of RAM. What to do with that 1 stick of 128? Sell it off to a friend.
    Ram works better in pairs. Also...depending on how much you want to spend. It may be overkill to get high performance DDR 400 memory. You won't use it effectively.
    The choice is yours and 2 x 256 or 2 x 512 MB PC2100 RAM will be a definite improvement.
    edited June 2004
    okay his internet crashing problem isn't his ram though i dont think, that is one nasty HJT log. DEXTER!!!!!!
    edited June 2004
    please read this post, and post a new log in the SVT forum here
  • edited June 2004
    New.net. You have spyware!
    Run adaware and spybot search and destroy now. Make sure you have a good antivirus software that's kept up to date. Make sure you have all your windows updates.
    KF
    //edit: I agree, that is one nasty hijackthis post. You have way too many programs running in background. Once the mess gets cleaned up you'll have a much better performing computer.
    edited June 2004
    http://download.com.com/3000-8022_4-10214379.html?tag=pop
    You can get Adaware at the above address.
    http://download.com.com/3000-8022_4-10289035.html?tag=pop
    You can get spybot at this address. Just download, run the updates, and check for problems. If it gives you a hard time, just check back here, we can walk you through it.
  • GHoosdumGHoosdum Icrontian
    edited June 2004
    If you don't have virus protection with current updates, you can download Avast! Antivirus at www.avast.com - they have a free home version that gives you free updates for 14 months if you register. After 14 months all you have to do is register again to continue to get free updates. Virus scanners and syware removal tools need updates to continue to be effective.
    All the spyware removal goodies can be found in one place here: http://www.short-media.com/download.php?dc=69
    edited June 2004
    For free anitivirus, I highly recommend AVG. It's free for home use. Updates are not as often as Norton, but are regular.
    edited June 2004
    I used AVG for a while and it was good, but Avast seems to update just as regularly as AVG, and you get more options you can set yourself.
    edited June 2004
    Thanks, I'll have to check it out.
  • ClutchClutch North Carolina New
    edited June 2004
    hmm, never heard of Avast. Even at work we put AVG on any machine we work on with out of date anti-virus, and it works like a charm. They have upgraded their servers in the past few months, updates would take forever a while ago, now they are fast as ever.
