HELP! P4 Cooling questions
So my laptop is a P4 (yea, yea, I know... stfu
) 2.4 Northwood. It runs a bit warm, and since the warranty is void now anyhow, I'm looking @ how to improve the cooling.
1. Does removing the IHS (that would be Integrated Heat Spreader for those of you that don't believe in acronyms) help?
2. Would lapping the P4's IHS be more beneficial than removing it?
I know I'm going to lap the laptop's heatsink, that's a given... I'm just not sure what, if anything, can be done to the CPU itself to help with cooling...
Any ideas?
) 2.4 Northwood. It runs a bit warm, and since the warranty is void now anyhow, I'm looking @ how to improve the cooling.1. Does removing the IHS (that would be Integrated Heat Spreader for those of you that don't believe in acronyms) help?
Any ideas?
TheBaron; the point of lapping is to make them flat. My grandparents own a machine shop. We've got granite blocks that are guaranteed to be flat to plus or minus like 0.001"... I'm in the office as I type this on my laptop. All I have to do is unscrew 6 screws for the CPU cover, 5 for the heatsink, 6 more for the 2 fans, walk down the street and lap it... And we've got sandpaper that goes all the way down to 1um (1 micron), which is equivalent to god only knows what grit of typical sandpaper- the stuff feels like silk, not abrasive paper.
j/k.
Can you find out want grit that paper is? Probably be impossible to find it at the local hardware store because it may be an insanely high grit paper.
You don't need to go that fine though. besides, do you know how fast copper clogs sandpaper? Try using this stuff- it's virtually worthless after only a few passes, and I doubt this stuff was cheap. Also, you'd be there all f**king week if you wanted to use this stuff... I mean once you got up to 2000 grit or so, you could go to 100um, to 75, to 50, to 25, to 5, to 1.... and when you start getting that fine, you're talking as much as an hour of sanding between grits simply because they remove so little material per pass... For all intents and purposes, all you need to go to is 600; 1200 is overkill (not in a bad way) and anything higher won't hurt. I went up to 2000 on my SLK-800, but it's not necessary.
Btw, I lapped it, so now the nickel plating is gone. I'm running F@H @ 100% load and it took the cpu fans like 5 minutes to come on, and the air coming out is damn hot.... ya know what? Lemme go grab my probe... just a sec (so I'm treating this like an IM... sue me)
It's been running F@H @ 100% now for about 15 minutes with no extra cooling, the air coming out the exhaust vent is reading around 132*F/56*C, which is a good thing. Why is having the air coming out of the heatsink that hot good? it means it's working. The hotter the heatsink gets before the fans kick in (they operate based on the cpu temp afaik), the more heat is going into the heatsink, and that's a good thing. I don't want the cpu to be hot, but I want the heatsink to be hot in this case. The only time a heatsink should be cool to the touch is when it's drastically overpowered for the device it's cooling. The fact that it gets hotter before the CPU fans turn on simply means it's absorbing the heat faster than it was before.
However, I had to use a massive amount of thermal compound on this thing. Not because the heatsink isn't flat (it's flat to 0.0003, if I recall the calibration certification on the side of this particular granite block correctly), but because the heatspreader isn't flat. I'd do something about that, but I know what metal shavings do to electronics, so I'll probably leave it...
Now that I've lapped it tho, it runs a lot cooler- the heatsink itself is just lukewarm at idle and the fans almost never run unless it's running F@H with no external cooling or something...
