Need peace and quiet... help?
Greetings...
My wife has been on my case about the noise level of my comp. The old comp wasn't all that silent either, but she seems to believe this newer one is worse. Though it doesn't bother me, she's begging me to find a way to quiet the thing down. Does anyone know what the quietest, good-quality fans are? Right now I'm just going with the stock heatsink/fan and a side case fan. It's the cpu fan that's so noisy. I'm using a Athlon XP 3000+ cpu. Advice would be appreciated.
My recommendation for a good, quiet CPU cooling is a Thermalright SLK-series heatsink with a good quality adjustable 80MM or 92MM fan.
what fan are you using now?
thermaltake smartfan2 is a good option. It can be quiet or loud or anything in between depending on how you set it up.
It can be controoled manually or by thermister.
The fan/heatsink on there right now was what came with it... called a Ultra Fire Athlon XP CPU Cooler. Stats are:
Fan speed: 4500 RPM
Airlfow: 21.5 cfm
Ball Bearing
Aluminum Fins, Copper core
It seems to cool just fine. If I can get the same cooling power with a lot less noise, please let me know. Also... can I just replace the fan and leave the heatsink attached?
1) Where is a good place to pick up the SLK-9x series heatsinks, at a good price?
2) Same question for the fan
3) What would a fan speed recommendation be if I did change to the heatsink/fan combo listed in your posts? Or is that just a thing you have to tweak?
And the fan is here ...http://www.sidewindercomputers.com/ther80smarfa1.html
I'll check out newegg ...
I don't think anyone mentioned what a good fan speed might be... is that just something you mess with and watch the temp?
You can use the thermistor which will raise and lower fan speeds as needed. Or you can set the speed manually at a comfortable rate yourself and leave it there. Even at 50% throttle you would have a very efficiently cooled system ...or even 25% throttle. You always have the option handy in the future for better throtling.
In your case I would try the thermister first. I set up a system just a few weeks ago that way and it was heavily overclocked (mobile 35w 2400+@2.4 200fsb) and the system is very very quiet and folds proteins 24/7 at 100% cpu usage and overclocked gpu.
Also ...if you are using an nforce2 motherboard there is a cooling patch you can apply which will cool your system 5-10 degrees.
Oh, and I spotted this in the BIOS: CPU Thermal-Throttling 50% , so it looks like I'm already set on that, unless I want to try 25% like you mentioned. I'd like to go with your suggestion of thermistor... once I know what it is. I'll go google now, but please post again when you have a min. thnx.
Here is the thermistor I mention:
...Potentiometer dial for manual adjustment, ultra-thin Thermistor with thermal tape, custom Thermaltake fan guard, a special 3+4 pin power adapter and 4 screws/bolts. The adapter allows the user to monitor the rpm while powering the fan safely from the power supply.
The thermistor is an optional thermal diode which will attach to the fan. It comes with the kit. It attaches to one of the leads shown in the lower right hand corner of the fan and the diode itself is attached to the wire at the other end. It is attached by double stick tape which you can adhere to the lowest area of the heatsink to get good temperature readings.
It works like this basically ...if your cpu temp goes up then the fan speeds up ...when your cpu temp gets lower then your fan speed slows down. Works very well.
While you're at it get some arctic silver 5 thermal paste. This will ensure proper contact between the sink and the cpu. Make sure before you power up that your fans are connected properly and your heatsink has good contact ...this essential so that you don't fry the cpu.
http://www.sidewindercomputers.com/arcticsilver5.html
This BIOS feature determines the clock speed of the processor when it is in the Suspend To RAM (STR) power saving mode. It has no effect when the processor is in normal active mode.
You can find a good bios guide here excellent for tweaking hints.
http://www.rojakpot.com/default.aspx?location=1
I used a similar thermal grease substance when I installed the CPU/heatsink just yesterday. It's probably not as high quality... I think I got a small injector of it for a buck or two. I very carefully applied it, as per instructions I've found on this forum and others. I think I did a pretty good job... so if need be I could do it again. I guess I'd have to clean off the old stuff with degreaser or something in order to reapply?
So, to all who read this string... what's the best/easiest/cheapest option? Go with the new heatsink/fan as the earlier messages provided? Or perhaps with the more recent idea of thermistor/fan combo, with variable speed based upon temp?
If so just get the fan and let it thermally control the speed itself.
If that's not quiet enough then proceed with a more efficient heatsink w/ grease.
Also ...try this patch if you have the nforce2 it should lower your temps therefore requiring less speed/noise.
http://www.tcmagazine.info/modules.php?op=modload&name=Downloads&file=index&req=viewdownloaddetails&lid=89
Heat Sink Dimensions: 62 x 80 40mm
Fan Dimensions: 60 x 60 x 25mm
Rated Voltage: 12V/0.20A
Power Consumption: 2.4W
Fan Speed: 4500RPM
Airflow: 21.5CFM
Can you do me a favor and link me to your case on newegg? I can't seem to find it. Once I've had a chance to look at the case, I can tell you what you'll need to get to quiet it down without cooking anything.
Still haven't decided what to go with, but I have options now, so I'm all set I think. If anyone else has more advice, please give a shout out... otherwise I'll pick from the options already presented. Thanks!
MBM has your sensors bass ackwards. The CPU is 47*C, the case is 39*C.
A sufficiently powerful fan can burn the fan power traces on a motherboard, yes.
I've got an aeroflow on Habitat For Humanity's server. On a stock 1800+ TBred, it runs 116*F under full load. That's... sad.
