Extreme water cooling?
The looks pretty extreme to me, but maybe that's because I've never water cooled myself, nor knew anyone--personally--that did.
http://members.monarch.net/npoirier/new_box/
Even with the 120mm fans turned way down my coolant temperature is extremely low (usually ~0.5’C above ambient air temp)
"With the 120mm fans maxed out the coolant gets as much as 3-5’C BELOW ambient :-)"
I find this quite amazing because there is a lot of heat going into the coolant (the pump alone puts out 60w)
The fastest I have ran my 1700+ was ~2800MHz (2700Mhz is 99% stable, 2600MHz 110% stable)
The fastest I am able to run my chipset is 220MHz (440 DDR) however I believe this is because I am only running the chipset at 1.7v (the max available before modding the motherboard)
I am able to overclock my GPU to 325MHz (275MHz is the default)
The line i marked says it all i think.
Nice setup though and yes, for watercooling that´s pretty extreme. He need to learn about physics though. Impossible to cool the water below ambient with eh... ambient air.
check my vodka cooled pc thread for an example
As far as I'm concerned, yes Vodka cooling is pretty extreme... but Vodka cooling with peltiers would be even more extreme
I just wish I knew it was going to be such a pain when I first started planning the computer... could've saved me almost 200 bucks in parts.
