Sony Laptop Display Problem
Ok... Sony PCG-FXA59 Laptop.
No LCD Display and no external display either. No BIOS screen, no OS screens, nothing. System seems to boot. but I cannot verify that. No apparent damage on the motherboard, I looked at the inverter and it seems fine...
My question (or validation to my answer) is... If no internal or external display, Video card is dead.
The user has no info on how this happened, or how long ago. I suppose to determine if it can be fixed for under $200. I'm thinking NO...
P.S. if youre system is under warranty, you will not pay anything..!!!
not even shipping.!!
It's not a driver problem because you get no display even before it gets into Windows. So maybe it's the CRT/LCD button (usually Function + F5 or something like that). I've had that happen to me a few times before on different laptops. You switch them on one day and they think that they should be sending the graphics signal through the TV-out socket to an external monitor, hence no picture on your screen.
i think..
LoL, its funny so said that prof.!! i was just about to post that info..!!
i have the same problem with sony PCG-FXA53
i need help any idea ..
best regard
try this pull the battery out then hold the power button down for 10 - 20 seconds
clears the bios
i try what u say (mybe i do somthing wrong)
so plz can u tell me more specificaton . like i let computer on then i left battry ....
the processor work the CDROM work i hear it . no data on LCD or even in external monetor..
so plz help me.
best regard
then plug in(don't worry about the battery) then try starting it
it is sounding more and more like the mother board, and or the vid card is fried
one more thing you can try is reseating the RAM , have seen this do the same thing
but it not work it the same problem
look like every thing is ok put nothing on LCD
1. turn all power off and remove the laptop battery
2. open the hatch (door) that covers the laptop memory module
3. pull out the memory (RAM) (do not touch the contact strip)
4. put the memory back in its slot
