Call of Duty Sound Problem
edited June 2005 in Hardware
hi my problem is when i play call of duty united offensive online my sound goes off completely after half an hour or so .
if i reboot my pc it comes back but then after a while it does it again .
i have the game on a virtual drive dont know if this matters but the problem is driving me mad,
p.s. i also use skype to talk to others mates time im playing and the sound on that goes out as well
  • PreacherPreacher Potomac, MD Icrontian
    edited June 2005
    Darren,
    I'd suggest you name your threads something relevant to your computer problem as opposed to your screen name. You'll get more people interested and thus willing to help.
    A little more info is needed. Are you using onboard sound or an add-in sound card? Do you have the same sound problems in other games and programs? Have you tried another sound card to see if you get the same problem?
    edited June 2005
    Thread title changed to be a little more relevant.
  • edited June 2005
  • edited June 2005
    hi again my sound card is onboard (asus motherboard) the chipset and bios are both up to date and although it happens mainly on call of duty it does happen some times on other programs also i have noticed that their doesnt seem to be sterio sounds comming out of the speakers
  • botheredbothered Manchester UK
    edited June 2005
    I've no idea if this is of any use but, I seem to remember having a sound problem with CoD ages ago that a new graphics driver fixed. I know that sounds odd (no pun intended) but I'm pretty sure that was it.
    edited June 2005
    It could be the sound portion of your mobo going bad or as bothered says a conflict with another driver. Have you changed any settings recently?
