PLEASE HELP, I Restored My eMachines And I Get A System
im hoping someone out there will help me out , i run my own internet bussiness and i have been out of bussiness for days now because of computer issues..
first off my emachines computer came with a system restore disk, i run it (symantec Ghost 7.0) and it says sucessfully restored then it will ask me to remove the disks and restart the computer when i do so and windows attemps to load up i get the error message ' windows could not start because the following file is missing or currupt: \WINDOWS\system32\config\SYSTEM .
i am not sure why its not working, the emachines restore disk has windows xp on it it automatically installs it. i cannot get it to start in safe mode,last known config,or start win normally
Your biggest handicap is the cheesy restore discs from emachines. If they didn't give you an actual WinXP disc you may have to borrow one.
Good luck.
fixboot
fixmbr
Make sure you hit {Enter} after each one.
It's a longshot, but worth the couple of minutes it will take you to try it.
