Fans, CD drives cutting out. Power supply prob?
I've been getting the odd problem since installing my new 64bit CPU. Every now and then my DVD and/or CD drives won't respond, sometimes they spin up but don't show up in My Computer. Recently I've been getting problems with my GFX card too. I have installed a Arctic Cooler on it and sometimes the fan cuts out. I wobble some wires and eventually it spins back up again, though I'm not sure if wobbling the wires did it. The only conclusion I can think of is that my power supply isn't strong enough for the bits and bobs in my PC.
I'm running an Asus A8V Deluxe mobo,
An AMD 64 3500
An Asus X800 XT PE gfx card.
I also have:
a floppy drive,
a DVD drive,
CD/RW,
3 hard drives (30GB, 40GB and 200GB)(all Maxtor),
and a TV tuner.
I think my power supply is a 350W or 450W.
Does anyone know what may be going on? Is it the power supply?
An AMD 64 3500
I also have:
a floppy drive,
a DVD drive,
CD/RW,
and a TV tuner.
It's a Powerup LC-B350AtX. 350W, not 450.
I've had a look around and found some Hiper power supplies and some Seasonic power supplies that run at anything up to 600W. If the voltage is that huge will it damage anything on the PC?
PS. If that is the problem can you reccomend any PSUs?
The first thing I'd do would be to replace those cables that you were talking about. I wouldn't rule that out. Also when buying a PSU, thats one of the things you dont want to go with a "no-name" brand because theyre cheaply put together and often have horrible soldering jobs along with bad internal parts.. Maybe its just me, but ive never heard of Hiper power supplies. I've had good luck with Antec, check those out.
PowerUp 350W power supply (LC-B350ATX)
Ratings from sticker:
3.3v = 28A
5.0v = 35A
12v = 16A
-5v = 0.3A
-12v = 0.8A
+5vsb = 2A
200W combined 5/3.3v max
192W 12v max
330W 3.3/5/12v max
total output 350W
Those Amperages are on the low end for a rig like yours.
Wattage is not the same as Voltage. That number shows what the PSU is capable of putting out if needed. Your system will only draw the power it needs; having more juice in reserve just provides a safety margin for sudden (temporary) spikes in current demand.
I'm not enough of an expert in particular brands and models, but I'm sure someone who is will happen along to advise you.
EDIT: And while I was typing this out someone already has.
Thanks again guy
One thing still boggles me though. On the benchmarks the voltage is often a little bit higher or a little bit lower than the +3.3V, +5V etc. Is it better to have a little bit higher or little bit lower?
+/- 10% nominal currency is acceptable for ordinary operations
+/- 5% nominal is acceptable for overclocked systems
If the system is overclocked or under heavy usage, a slight overvoltage is better than under voltage. The most important voltages, the ones that must be closest to the nominal (stated, required) are the +12v and 3.3v
I would say though, that if the voltage fluctuates 10%, such as your 12v 'rail' dropping to 10.8v, you have a substandard power supply unit. My overclocked systems will not tolerate even a 5% undervoltage.
The biggest demands on a PC are normally going to be 12 volt, followed by 3.3 volt.
[edit]
Has anyone heard of Enermax? I've seen some good PSUs on Overclockers.
sorry, i have just never heard of them so im assuming theyre not the greatest. But with a price tag of that they better be good.
When you say they output higher than spec, do you mean they preform very well, or they literally perform higher than spec. For you dont want the 12 volt to be running at 13, or the core to be running at like 2 volts, because that would kill your parts. The closer the actual out put is to the deisred voltages, sorry i have no clue what you would call them, but the 12v, 5v, 3v, and core which is different for most pc's. but anyway you dont want the readings too far of those numbers or it means youl have alot of problems.
In the old days, some stereo companies used to cheat and measure the output of their amplifiers in POP (Peak Output Power). They'd measure the power surge at its peak level, then try to tell you that the thing actually was that powerful. A more accurate measure would be what the device can supply on a constant basis, leading to the adoption of the RMS (Root-Mean-Square) standard, which averages out the peaks and valleys to provide a truer picture of its capability.
I have a basic idea of the theory, but I'm not so hot on keeping up with current brands and models of individual PSU's.
Now, if I had some idea as to what to make of this mess...
