What rated power supply will i need for this machine?
AMD Athlon 64 X2 3800+ "Manchester" ~2000MHz
ASUS A8N-SLI Nforce4
1024MB (2x512MB) Kingston ValueRAM PC2700/DDR333 Dual-Channel
BFG Tech BFGR78256GTOC Geforce 7800GT 256MB 256-bit GDDR3 VIVO PCI-E x16
Western Digital 200GB 8MB Cache IDE 7200RPM HDD WD2000JB-00GVA0
Seagate 120GB 8MB Cache IDE 7200RPM HDD ST3120022A
USB Creative Sound Blaster Audigy 2 NX
iomega Dual DVD 4x2.4x4x2 DVD +/- RW DVDRW4216IND-A
iomega 52x24x52 CDRW CDRW64896INT-B
Panasonic 3.5" Floppy Drive
Philips 109B5 19" Flat CRT Monitor (1280x1024 85Hz)
Creative Inspire 5200 5.1 Speakers
Logitech Cordless rechargable mouse MX700
Logitech Cordless Elite Keyboard
Thermaltake Xaser 'Shark' Silver Aluminium ATX Case
Undetermined PSU
Cooler Master Aerogate II Fan Controller (Black)
Posted a full system spec list. Basically, the new items are the Athlon X2, The A8N-SLI, and the 7800GT. Still waiting on these parts, of course, but i'm interested to know in advance, what power supply would be the cheapest and most effective in this situation. Please keep in mind i'm Australian, so links to products available in Australia would be ideal. My current power supply which runs an Athlon XP2600+, a R9600XT, and everything else above (less the new gear, of course) is a Thermaltake W0009R, which can be found here. I'm extremely confident i need something alot bigger, particularly if down the road, i decided to run two 7800GT's in SLI mode
. Input?
Undetermined PSU
. Input? 0
All our high end puters run 500w. No probs with these Blue Storm 500w.
120mm fan, 24 pin, made by Fortron.
Also use Superflower 500w.
140mm fan.
Depending where in Oz you are as to where to get the best deal.
I only know the local ones in W.A. for the best prices.
Google is your best friend for that.
But I have one question for you.
Why such a high end system and such bad memory? :[]
I'm from Albury, New South Wales. Closest capital is Melbourne.
Local retailers are EXTREMELY overpriced, so recommendations for Melbourne/Sydney would be best.
Cheapest i have seen from doing online searching is MSY.
Wish they were in W.A. Don't really know if this helps you, but worth a shot.
Generally if it's not available locally, we order from a shop in Sydney. Unfortunately it's the other side of the country. Distance of around 4,400K's.
The things we do to feed a habit, lol.
Also, from what i can see, the cheapest online store in Australia would probably be Centre Com - www.centrecom.com.au
I purchased the Antec Truecontrol 2.0 550W. SLI certified, and powerful.
