Motherboard power problems!!!
Hey guys
i'm using the asus a8n-sli deluxe for my first build. I got it up and running and had windows installed in a few hours.
The next day when i went to turn on my comp it would not start. I opened it up and checked all the connections and they seemed fine. I thought maybe the power supply was my problem but the green led light on the Motherboard was lighting up but none of the fans or anything were working.
I went out and bought another power supply and it was the same problem. The thing is if I dont push the 24 pin connector all the way down on the Motherboard i can get my fans running but as soon as its cliped in the fans stop. I'm thinking of returning the motherboard for another but i was wondering if maybe it could be something else.
thanks in adavnce!
thanks in adavnce!
1) Remove the CMOS battery for about 15-20 minutes, then re-insert and try again..
2) Remove the motherboard from the case, take everything apart, remount CPU, heatsink etc. Try again once everything is reassembled. This simple action has helped me on numerous occasions
Good luck
Return the motherboard for a replacement.
I agree with Leonardo, at this point, it looks like there must be a broken trace or something physically wrong with the mainboard..
Good luck!
