Continuous Loop Problem At First, Now Nothing?
I recently got an HP Pavilion P8626A Desktop Computer with Windows XP on it, but it's in non-working condition. At first I would get a blue screen with a repetitive loop that would go on forever until I held the power button down to make the computer turn off. I guess a friend of mine "heard" that by removing the CMOS battery, for a certain amount of time and then putting it back in, would solve the problem but things just seem to have gotten worse. I put the battery back in and now I don't get no blue screen or nothing no image at all. I turn the computer on and it seems to start but then again the Tower light just stays orange, and so does the light for the screen and nothing happens beyond this point, not even the blue screen I would get at the beginning. I would like to see if I can save this PC or if it's too late for that?
when you power on the machine does it seem "on" other than the lights, by which i mean fans spinnning and CD-ROM drives eject and such?
"Am I able to say now "it's too late to save this PC""?
Alot of this depends on how much you are willing to do to get it running. Mostly what it will take to find the problem is patience, fixing the problem might take a little more.
As far as a vid card, It would help. I would try to borrow a pci vid card from somebody, or your working machine if possible. No point in laying out the cash if you don't have to.:)
Are the blank slots in the troublesome machine white in color?
is it one beep or a sequence of beeps?
if it is a sequence of beeps please write them as they are beeped denoted in long an short beep.
for instance, one beep code might be long, long, short, long.
if im not mistaken long beeps are usually 1/2 to 1 second long and the short beeps are, well, short. they should be easy to distinguishe from one another.
is the black slot really long or just a little bit longer than the whit slots?
and with the top of the board being closest to the power supply, where is the black slot, closer to the top, or the bottom? (is it on top of the white slots or below them?)
All your really looking to do it to try to get some kind of display. You might have luck calling your local computer shops, they might have a working "pull" out of an old machine. Or maybe something like a pc "junkyard" that specializes in used parts. It might be a little low tech. but your local phone book might help you out a bunch.
Okay so it was at one point booting...although it was in the loop so to speak.
You did put the battery back in correctly...ie: + sign facing up ? What else did you do inside the case ? How about static electricity, did you notice any finger tip sparks when you took out the battery ? If all the above checks out I'm thinking maybe the bios has died...I say that because going by what you say your not even getting bios beep codes.
Then there's Bad Flash.
Looks to me as if that board has a bios chip that can be replaced...but ya know if the bios is dead or maybe even the AGP bus has gone south although I would think that if the AGP is pooched you'd still get a beep code indicating the failure. If it was me I would just toss it in the trash...you can get a comparable or better socket A mother board for like 50-100 bucks...you'd pay 30+ with shipping for a new bios.
In response to the above about the pci vid card...I tend to really think he's had a fatal failure...no bios beep codes of any kind usually spells DEAD something. The Award bios beep code for a video error on that motherboard should be 1 long and 2 short.
edit: You never mentioned if the battery was reinstalled correctly so I take that it is ?
If your CPU was dying that could explain the original loop situation...
Your situation now of no post AND no bios beep code could mean the cpu has totally died...
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&lang=en&cc=us&product=83478&dlc=en&docname=bph07585
If any of you could help me find a motherboard for my machine? Again, if you COULD, I would greatly appreciate it, then again it's no obligation as I already have one working machine, so far.. thanks for everything to all.
lol...trust me I've seen a couple come in installed bacwards
If your 100% sure the cpu is good then anything socket A\micro ATX should do the trick, something like this MSI would get you going cheaply.
Click Me
Also one of my kids computers uses an ECS 741GX-M, it's socket A and micro ATX and so far it's been flawless.
Cheers
