trying to reformat scsi hard drive, will not detect my drive
I am trying to reformat my hard drive from Xp home and reinstall XP home, but when I boot up with the CD it wont detect my SCSI hard drive when I select ENTER in the options screen. My drive boots up perfectly when I run the computer normally. My computer came with only 1 dvd rom when I first got it but i installed a second from my old computer and it installed itself and has worked perfectly fine. could that possibly have something to do with it, and would anyone know how to get the system to detect my hard drive so I can reformat.
Also, does anyone know why I can't open any links on Internet explorer? Any link freezes and will not open.
Please help, Thank you!
thanx for your relpy.
where would i find the drivers for my drive?
If it's a separate card, see what's written on it.
Prof will pull up my slack!!
the drivers listed ar under windows/system32/drivres/disk and partmgr
i put those 2 fils on a floppy but it says, can not find file txtsetup.oem after pressing F6 to manually install them.
The contents of "drvdisk" is what you want to put on your floppy disk.
Thanx for everyones response so far, i hope i can get thi issue resolved soon.
Your hard drive model: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=1026&p_created=1056554169
SATA drivers at the bottom of this page: http://www.biostar.com.tw/support/driver/model.php3?name=K8M800-M7A
Check this out.
//edit// Man, I take forever to post.
I can now view my raid tool and it mentions my drive at:
PHYSICAL POSTION, controller 0, channel 0, Master
ARRAY POSITION, Not in any disk array
DEVICE STATUS, Normal
GENERAL CONFIG, SATA Device.
Could the controller postition have something to do with it?
Tried that, still the same thing. the exact message i get is:
"Setup did not find any hard disk drives in your computer."
"Make sure any hard disk drives are powered on and properly connected to your computer and that any disk-related hardware configuration is correct. This may involve running any manufacturer supplied diagnostic or setup program."
But when I boot up windows normally, it works fine, but I am reformatting because of problems I have with internet explorer which I tried everything to overcome (including a reinstall from my XP cd) but still have issues and have everything backed up anyway since my pc is fairly new and didn't have much on it yet anyway.
I also noticed that my bios seems to have no info on my hard drive but only my cd drives and floppy.
txtsetup.oem
bb-run.sys
Fasttx2k.cat
fasttx2k.INF
fasttx2k.sys
ptipbmf.dll
readme.txt
Most of the file names had 1 dupilcate with a different file size and tried it once overwriting when promted when transfering to floppy and tried it once without overwriting but they both didnt seem to work.
All of thes files were downloaded from the WD site for this drive and I threw them all on a floppy, and it mentioned they were compatible for win2k, win03 and XP.
Copy the ones from this folder: viasata-4.30G\drvdisk\AMD64
Link
So you’re only providing drivers for the sata controller not the actual hard drives. Once the controller is installed it takes over operating the drive.
I have downloaded that already earlier and attempted to try it again, and installed it, but i can't find the file viasata-4.30\drvdisk\amd64 within it since it just installes the program, do you know where i can find that file, is that waht i need to put on a floppy, or is it supposed to work after i install the program, i still have the same problem if that is the issue.
the big issue i am having is i cant open any link that has been givin here that brings up a new window in internet explorer so i have to retype the whole address manually and some links dont include the whole address so I hope I am getting the proper place, is the file size 6.55MB this seems like the file you are mentioning.
Thanx again.
These are the files.
Try these!
Then when you are asked for installation of drivers (~2 minutes later), just install the SATA drivers from the floppy.
Keep the floppy in the floppy driver until asked to remove it.
