No Power to MoBo, Replaced PS w/650W still NO POWER, help.
Hi,
Problem: Machine will not power up, merely spins cpu cooling fan and begins to power up disks before loosing all power after 1-2 seconds. Then pushing power button does nothing, no fans or disks spinning.
Machine:
MoBo: PC400 M930 478
Processor: P4 1.2GHz (non-hyperthreading)
1 GB PC133 SDRAM memory (2 -512s)
10 MB ethernet on mobo
2 serial connections
1 parallel port
2 USB 1.0 ports
Sound on mobo not used.
PS: Brand new MGE 600 Watt PS (fully tested by me)
Disk Drives: 3 WD 80 GB drives
Optical Drives: 1 - CDROM R/W, 1 - DVD R/W
AMR: 1 - modem
AGP: 4x - nVidia p162 video card w/ onboard cooling fan
PCI:
Sound Blaster Live CT4830
1 IDE adapter board w/ 2 controllers
1 5 bay USB 2.0 adapter
1 2 bay Firewire/3 bay USB 2.0 adapter
Other:
3 cooling fans (1 over heatsink, 1 front intake, 1 rear exhaust)
Current Observations (with only monitor and PS/2's connected):
1. PS rechecked and OK w/PS checking device,
2. This is a real mystery to me: With mobo atx 20 pin main power disconnected and power button pushed all fans, disk drives, spin up to what seems to be operating speeds (I shut it down after 5 seconds). However, once atx 20 power re-connected the original problem of a 1-2 second "spurt" of power to fans and disks occurs.
Unusual Traits: When friend brought me the machine it acted in a similar fashion with 450W PS. I thought it was underpowered with all of the PCI connections, and to test my theory I removed power from the two PCI connected disk drives and hit the power button and the machine began to POST. Now that I've replaced the PS it won't even do that?
I'd appreciate any suggestions or thoughts as to this situation, as I've already spent $79.00 on a good PS and it doesn't fix the problem :banghead: .
Thanks,
HBI1000
Machine:
1 parallel port
2 USB 1.0 ports
AMR: 1 - modem
PCI:
Other:
Thanks,
HBI1000
HBI1000
And Leo, since that system has a P4 1.2 proc, it is a socket 423 Williamette board, which I don't have much experience messing with. So I don't know if it has the auto shutdown with no fan connected feature, since it's such an old board.
