Problem with MBM 5
Long Version
Short version:
I just installed a new processor (socket 939 athlon 64 3000+ venice), and I'm in the process of burning it in and also preparing it for overclocking (in a few weeks).
I've been reading the great overclocking guide, and I downloaded MBM 5 to monitor my cpu and case temps.
I tried it out today, and (long story short) I found out that MBM 5 might not be entirely reliable. I knew the people at short media would be glad to help, so that's why I'm posting here
I really need a reliable motherboard monitor if I ever hope to overclock my cpu in the future, so I was hoping that somebody could point out a more reliable monitor for me to use.
Thanks very much in advance.
Short version:
They quit supporting MBM5 a while back. Although it still works fine for some boards, that is not always the case. Are you sure that the sensors built into the board have been identified correctly?
A similar program you may wish to try is SpeedFan. Like MBM5, it is free.
I recently had to migrate away from MBM, which I had used for years.
Thanks for the help
(PS: Under 100% cpu use, my cpu peaks at 34 degrees Celsius
Glad you got it going.
linky http://www.thecoolest.zerobrains.com/forums/viewtopic.php?t=137
