Asus P4T-E System Shutdown Problems
I've got an Asus P4T-E with a 1.8GHz P4 Northwood, 512MB of PC800, and an Antec True380 PSU. The computer will, after varying periods of activity, shut down for no apparent reason. It'll be behaving normally and then all of a sudden the fans slow to about half speed and then everything turns off. The temperatures all look good and the voltages, though a little low, are still within tolerance. After it shuts down, any attempts to start the machine result in a processor failure siren. This activity started about a week ago though the computer has been functioning normally for the past few years.
I tried swapping out the power supply and the processor, neither of which had any effect.
Ideas?
-drasnor
Ideas?
-drasnor
-drasnor
Can you use something like MBM5 to log voltages? If so, make sure it updates the log frequently enough to allow you a chance to spot a glitch.
-drasnor
-drasnor
