help with audio dowloads
I am trying to download and burn some audio files and need some help. There are fourteen files I want to fit onto one disc -- a total of 23.8 MB -- my disc is an 700MB. When I go into my Windows Media Player is shows that the last 6 files "will not fit". I've tried to lower the burning speed but I still can't get it to work. It seems to me that it should fit, what can I do?? TIA!
Thanks! I know better than that but must have got in too big a hurry and screwed up. I know nothing about primesuspect. What do I do?? TIA
Welcome to Short-Media!
If you switch to nero, there is a green bar at the bottom of the screen that will turn red if you go over 80minutes.
BTW don't forget to normalize your songs before burning them. That would make the volume of all of them to be similar.
