Help!!!
edited August 2006 in Nerdery
I was partitioning my disk to install linux, and after i installed I didnt like the distro I I just deleted the partition, i used Partition Magic, and after i deleted I rebooted and I got this message
"L 99 99 99 99 99.." and many more sets of 99's How can I fix this!!!
    edited August 2006
    Looks like the GRUB boot loader is still installed. You'll need to clear the Master Boot Record.
    This information is offered AS-IS. I am not responsible for loss of data. If you choose to follow these steps, you do so at your own risk!
    Get yourself a Windows 98 boot disk (try www.bootdisk.com). Boot the disk and at the A: prompt, type in FDISK /MBR and hit enter. I forget if it prompts you or not. If so, allow it to do its thing. Reboot, and you should be back in business.
