Looking at upgrade parts, need a bit of advice.
Greetings. I was just looking for some input on these components I was planning on purchasing very soon.
Heatsink: Scythe NINJA PLUS
CPU: INTEL E6600 Core 2 Duo OEM
RAM: OCZ DDR2 PC2-6400 / 800MHz / Titanium XTC / EPP-Ready Edition / Dual Channel
Motherboard: EVGA NF680i Motherboard
And I am going to get a nice Hiper PowerSupply along with all of that (530watts). Now, I was just looking for some input. Furthmore, should I hold off entill Asus releases the Stryker motherboard? Thanks in advance!
For your HSF, I would actually recommend a Thermalright Ultra-120. It runs a few degrees cooler, and looks really good.
I would wait another month on the 680i, though. A few manufacturers (Like Asus) will be releasing non-reference 680i boards soon, and they could be real doozies.
EDIT: Dodger, one thing I have read is that the U-120 and Tuniq Tower both are easier to mount than the Ninja. I have a Ninja and it's a bit of a PITA to mount in the case. Spend the extra bones and buy the U-120 or Tuniq Tower 120.
Thread is here and nVidia has recreated the problem.
Datsun 1600
Good, hold off on buying for a few weeks then. There should be something for you to read in a couple of weeks here.
