Low power fans
fudgamfudgam Upstate New York
I would like to get a clear case with led fans for case fans. Problem is all the 80mm led fans peak at about 34 CFM. I would like fans that are atleast 45, or is that the peak for 80mm? As for the case, I'm thinking about getting the x-clear from xoxide.com. Newegg and tigerdirect didnt have any clear cases. Any other site suggestions would be nice.
    edited October 2003
    There's only one 80mm LED fan that I'm aware of that'll push 45cfm+, and it's not even a true LED fan. The Thermaltake Smart Fan2 with "CoolMod" will fit the bill, but it's an orange fan with an LED fan grill, not a clear LED fan. Outside of that, there's nothing out there that can do what you want.
    Also, check out www.nexfan.com ... they generally have fans at much lower prices than Newegg...
  • fudgamfudgam Upstate New York
    edited October 2003
    Funny sh*t man, I saw someone selling a white LED lol
    edited October 2003
    Huh? I don't get it...
    They make white LEDs... I've got a good 15 or 20 of them, in fact...
    edited October 2003
    I would think that people would want color if they are getting LEDs
  • SimGuySimGuy Ottawa, Canada
    edited October 2003
    There are also infrared LED's, which emit light that cannot be seen by the naked human eye :)
    edited October 2003
    yea, ive seen them. In a clear case though, i think the case itsself will be illuminated and you wont be able to see inside, atleast around the fans.
    edited October 2003
    Fudgam, it depends on what you're using the LEDs for. In this case (no pun intended), yeah, you'd probably want color LEDs. However, I'm using some of mine for a flashlight. I just need to order a few dozen more (I'm thinking a total of like, 50... @ 9300mcd each. They have a narrow beam, but it doesn't matter with that number of light sources)
