System Won't Power Up After Motherboard Swap
hey guys, I've got a problem, I just changed my motherboard and processor and 1st, when I plug in the cable (pc still turned off) the keyboard lights are already on (!) 2nd, the pc won't even start when I try to switch it on... what the hell could it be?! the most important info:
- Athlon XP. 2500+
- Gigabyte 7N400 Pro2
- Zalman CNPS6000CU (with FanMate 2)
- 512 Kingstone 400MHZ ddr ram
I have this very strange idea that there might be a problem with the tower.. that there's something wrong with the button.. but that wouldn't explain the keyboard light, does it?
thx guys, francesco.
ps. I think I just posted on the same forum but in another section.. if so I apologize but it's a real emergency..
- Athlon XP. 2500+
1. The connectors (power switch, HDD LED, power LED...) to the system panel (far lower right of the motherboard) are on the wrongs pins or are oriented wrong. Recheck your motherboard manual for proper pin placement and connector orientation.
2. The motherboard may not be grounded properly. It could be the brass standoffs are not snug against the computer case and/or the motherboard is not snug against the standoffs. If those contacts are not secure, your motherboard will short out and nothing will happen except for odd LED or two lighting. If solution '1' above does not work, remove the motherboard, place it on a piece of cardboard or something else non-static, connect one stick of RAM, the main ATX power cable, and the power on/off switch from your case. If the CPU heatsink's fan spins, your motherboard is probably good, but just was not grounded correctly when installed in the case.
I have made mistakes with respect to '1' many times. Those tiny connectors are very easy to misalign on the panel pins.
francesco. I noticed that there is a small V on the back of each pin, does that mean anything, is that maybe the "+" side?
LOL, I know, sounds ridiculous.. ha ha ha.. man, thx 4 ur help, I'm gonna try it this afternoon (still some hours to go here in Barcelona) and then I'll post again..
gracias!
Come back if you still have problems. Well, come back regardless and let us know how it goes. You are welcomed to become active in our community.
