Metal Gear Box Substance power supply
I have a USB2/SATA Metal Gear Box Substance external HD case but need an additional power supply. I've tried to find the part number online but it's been a no-go. Anyone have an idea where to get one?
Here are the specs that are listed on the power supply.
Put Powertech, Inc.
Switching Adapter
Model: PPS25A-D0(00A)
AC Input: 100-240v - .6A
DC Output: +5V---1.5A
+12V---1.5A
Any help is appreciated. I guess I could simply purchase another, but then that's a pricey power cord...
Thanks!
Put Powertech, Inc.
Switching Adapter
+12V---1.5A
Thanks!
above is an image of it from techimo
Good idea but probably unlikely
SkyDiver You might be better off contacting the manufacturer and trying to get a replacement psu.
You could build a little breadboard. I am sure that you can get both voltages out of one dual wound transformer and just slap a couple of diodes on them.
Hmm, maybe not the Metal Gear brand. They are very nice - rugged, easy to use, designed to be opened frequently, and aluminum case that vents heat away very nicely. I've got one and have used it for years, but for some reason it won't accept large capacity Seagate drives...
but that's another topic for another thread.
Thanks for this link! I just ordered my replacement part. I really like the Metal Gear Box enclosure but I had an unfortunate experience with eGoodz. I ordered two of their enclosures and everything came in the box except these power supplies. In their stead were regular old three prong power cables. Of course there is no way to use them alone with the enclosure. I called their customer service reps and after three or four conversations I finally convinced them I was not trying to get something for nothing. I don't think they believed me at first. Over a month later and I got a package in today's mail. They sent me *one* of the two I asked for. So rather than go through all of that again, I did a Google search which put me right on this thread. Thanks a lot!
a) dishonest
b) disorganizied
c) lacks moral leadership
d) has incompetent leadership, or
e) all the above Unfortunate? No, I'd say your experience with those baffoons (creeps) was on par for their typical service, at least according to reselleratings.com.
Gentlemen, whenever you deal with a little-known company online, do yourself a GREAT service and check them out first at Resellerratings. It might very well save you a lot of heartache. There are many sterling, honorable online sellers, but there are also thousands of schlocks and losers just waiting to rip you off.
It's a dangerous thing purchasing from a seller merely because some price check service lists them as "lowest price." All to often the lowest price is lowest for a reason.
I need the same switching adapter. Did the one you ordered online work with your Metal Gear Box enclosure? http://icrontic.com/forum/images/smilies/confused.gif
Thanks.
