Heat monitor problem
I'll check what temperature my cpu is running at in bios (after about an hour of running) and it would list about 36°C. But if I check in windowsXP with asus probe 2 it will say about 50°C.
To make things weirder: I'll have my comp running for about a day and the asus probe reading in windows will stay the same. But when I check in bios it will skyrocket to over 70°C.
So which one is more accurate? The bios reading or the program in windows.
I'm running an XP2100+ @ 2.16 ghz on an asus a7n8x-deluxe if you're wondering.
My computer doesn't crash at all so I'm thinking the 70°C reading is wrong. The usual 50°C reading I get is high but it isn't as sinister as 70.
Try MBM5 to monitor temps. I have had bugs and probs with the asus util at times.
Tex
I'm running MBM5 right now. My mobo is reading 37°C, CPU socket at 50°C, and the diode at around 60°C.
Thanks for clearing it up
60*C is TOO HOT... what heatsink/fan are you using anyhow?
