Power Supply Suggestions?
I need a new power supply. My cheapie 300w that I have right now can't handle the load. The 12v rail is always at 11v, and I think it is causing my pc to hang.
I don't want something too expensive, should be somewhat quiet, and between 400 and 500 watts.
Here are a few that I am looking at:
http://www.thermaltake.com/purepower/W001011.htm
http://www.kingwin.com/pdut_detail.asp?LineID=&CateID=2&ID=117
http://www.enermax.com.tw/eg365p-ve-fma.htm
Opinions?
Opinions?
http://www.antec-inc.com/pro_details_enclosure.php?ProdID=15138#
2. What case do you have now?
3. As Al said also, what are the system's specifications?
1700 tbred b @2408 (14*172) on a NF7-S v2. I can go higher but XP hangs. I think it is because the 12v rail is only 11v.
The 3 power supplies listed are between $100-$120 CDN.
The Antec case is only $135 CDN.
$150 CDN is too expensive.
I've got the SLK-3700AMB, which is the same case without the fancy punched antec logo, a dual-fan SL-350 Antec PS, and a relocated 120mm intake fan (in front of HDD cage, with the HDDs mounted in their normal front-rear orientation).
It's crap. I hate it. It's fine for stock systems, but it can't handle the heat output of a 2.4GHz 1700... trust me on this one, I had a 1700 @ 2.3GHz in it at one point. I even went so far as to strap a 131cfm 120mm fan on the back. It still couldn't handle it.
The ventillation just plain sucks. I modified mine with 2 80mm blowholes, and the ventillation STILL sucks. The case has been relegated to use with my 1.3GHz Celeron @ 1.5GHz Print Server because that's the only computer I have that runs cool enough that it can handle the heat.
I've used it on stock AMD systems up to 2800+, but at those speeds the top of the case gets noticeably hot because air gets trapped up there.
Bottom line: don't waste your money.
That InWin case tho, really needs to go... (hey, that rhymes...
Get an Antec power supply, and a new case. There are a ton of cases out there that could be made into decent ones, but I still think that Antec's performance series cases (and the OEM versions of them) are great. If you can get an Antec SX830/835, that would be perfect. They're better than the SX10x0 cases, in fact.
Barring that, there are a number of other cases that are decent, but I'm not familiar with canadian computer stores, so you'd have to give me links to places you'd buy one from and I could take a look...
Enermax
PC Power & Cooling
Allied
PowMan/InWin
And any manufacturer on AMD's approved PS vendor list should be fine, as long as you buy one that's big enough for your needs.
I swapped in another one I had laying around.
Thanks for the suggestions, they will help narrow down my choices a bit.
http://www.antec-inc.com/pro_details_enclosure.php?ProdID=91082
