Front-panel case connector and motherboard seem incompatible
I've been working on setting up a new computer, and everything was going swimmingly until it was time to plug the front panel connector from the PowerSpec TX-366 case into the motherboard, an ASUS M2A-VM board. Instead of the familiar gaggle of two-pin connectors, though, I was faced with a single 5x2 connector with eight wires plugged in laid out something like this (x's represent wires):
x x x [closed]
x x x [empty]
Whereas the connector on the motherboard looks something like this:
This, as one can see, presents problems for wanting to actually turn the damn thing on. Is there any way I can reconfigure the wires or something in order to plug it in, or are the two simply incompatible and I should replace one of them?
x x x [closed]
x x x [empty]
Zeph, how and where did you acquire that "PowerSpec TX-366" case? It's rather small and is a rather obscure brand. Perhaps the quality is qood and it suits your needs. I'm just wondering if that's a case that was designed primarily for OEMs but not for retail customers.
I ended up removing the wires from the connector and tracing the wires as best I could. Worked out just fine.
You just connect the first eight plugs or holes. The bottom of the panel plug has only one hole, so you overlap it (not connected to anything). Hope that makes sense.
