atx 12v problem
Alright im not exacly sure what is wrong but this what i got for ya. My computer randomly shut off the other day when i got home it was off. When trying to start it up it runs for around 2 secs then off. I then took everything off my motherboard and when i tryed just power supply in motherboard same problem. Then i unplugged the 4 pin (atx 12v) Then it fixed it powered up and everything and stayed powered. I plugged everything in and still it powered up but i didnt get beeps or graphics card working.
Is there anything i can do my power supply and fans work without the 4 pin but my graphics card doest work. but when 4 pin is in it just powers up for 2 secs.
Any help would be great.
ps: running an amd 64 athlon 3700+
BTW, more advance motherboards require an EPS12V connector, that's 2XATX 12v connector. All my motherboards are that way.
Any ideas before i order a motherboard.
1) remove/disconnect unnecessary components to rule them out as problems
2) test with only one stick of RAM, test each stick one at a time (doubtful that both sticks would go bad at the same time, so test individually)
3) test with a different PSU
4) reset BIOS to defaults and test
Sounds like you've done most of this. If you are sure your RAM is good and there are no buggy components in the PCI/e slots, then yes, it would appear you need a motherboard replacement.
