Help! PSU missing parts??
I am upgrading my system and am in the middle of installing my PSU (Nspire X-extreme 600W) and just realized that it didn't come with a 12V 4-pin (square) cable. This confuses me because my old power supply (Ultra X-connect 500W) had the 12V cable, but this may have been because it only had a 20-pin ATX cable instead a 24-pin cable like my new PSU.
Why would this cable not be included in the packaging? Can I still run my Intel Core2 Duo without it? Are a lot of PSU's not coming with the 12V cable now or is this odd that it doesn't have it?
Any help would be great because I don't want to fire up my computer without this cable in case it could cause some damage. Thanks in advance.
Yes it does! And as I look close it seems as if I can pull it apart on one end revealing a 4-pin connection. I'm assuming this is the 12V cable I couldn't find, right?
Why would it originally have 8-pins before I pulled it apart? Do some boards have an 8-pin 12V connector instead of a 4-pin one?
Yes.
http://icrontic.com/forum/showthread.php?t=67655
