Building first Intel system, need help with FSB and memory.
So i've been used to AMD for the last few years and i've forgotten how to do all this fsb and memory speed matching. I'm looking to get a Core 2 Duo E6750 which has a 1333 FSB. If i get this Gigabyte motherboard with it which has a memory standard of 1066, what kind of memory should i be looking for?
The best you'll be able to do is a 333MHz FSB on a 3:2 divider giving you 500MHz/PC2-8000/DDR-1000 for the RAM.
There's the FSB speed.
There's the memory speed.
These can be equal, or separate.
The enthusiast community speaks of FSBs in <b>actual</b> megahertz. Be it 266, 333, 400, 500 or 533. When it comes to RAM, most people speak of the bandwidth (6400, 5300, 8000, 8400, etc.)
Now here's where it gets confusing:
Intel rates all their chips with the FSB * 4. That's why 333.33 <b>real</b> MHz is 1333 on Intel adverts.
RAM is FSB * 2, which is why a 333MHz FSB uses DDR2-667.
FSB * 2 * 8 is the bandwidth of the memory, which is why DDR2-667 is also known as PC2-5300.
Here's a quick cheat sheat:
266MHz FSB = DDR2-533 = PC2-4200
333MHz FSB = DDR2-667 = PC2-5300
400MHz FSB = DDR2-800 = PC2-6700
500MHz FSB = DDR2-1000 = PC2-8000
533MHz FSB = DDR2-1066 = PC2-8500
Now, this assumes you're running the FSB and RAM at the same speed which Intel does not do by default. It's not like old Athlon XPs.
So, there are these neat things called dividers. It's two numbers that you, literally, divide to get a number. You multiply the FSB by this number, and that is the resulting RAM speed. The most common ones are as follows:
1:2 = 0.50
2:3 = 0.67
3:4 = 0.75
4:5 = 0.80
5:6 = 0.83
6:7 = 0.85
7:6 = 1.16
6:5 = 1.20
5:4 = 1.25
4:3 = 1.33
3:2 = 1.50
2:1 = 2.00
Now, Intel officially recognizes two FSB speeds for their chips:
266
333
Now, here are the RAM speeds you can run with 266 FSB Core 2s (On most motherboards worth their salt):
266 FSB @ 1:1 (1.00) = 266.66MHz RAM * 2 = DDR2-533 * 8 = PC2-4300.
266 FSB @ 5:4 (1.25) = 333MHz RAM * 2 = DDR2-667 * 8 = PC2-5400.
266 FSB @ 3:2 (1.5) = 400MHz RAM * 2 = DDR2-800 * 8 = PC2-6400.
266 FSB @ 2:1 (2.0) = 533MHz RAM * 2 = DDR2-1066 * 8 = PC2-8500.
Now, here are the RAM speeds you can run with 333 FSB Core 2s (On most motherboards worth their salt):
333 FSB @ 4:5 (0.80) = 266MHz RAM * 2 = DDR2-533 * 8 = PC2-4300
333 FSB @ 1:1 (1.00) = 333.33MHz RAM * 2 = DDR2-667 * 8 = PC2-5400
333 FSB @ 6:5 (1.20) = 400MHz RAM * 2 = DDR2-800 * 8 = PC2-6700
333 FSB @ 3:2 (1.50) = 500MHz RAM * 2 = DDR2-1000 * 8 = PC2-8000
Now, nothing is stopping you from running ANY FSB frequency at 1:1 with your RAM, but you better make damn sure that your components can handle it. A lot of overclockers do 500MHz FSB, 500MHz RAM and use PC2-8000/DDR2-1000.
In summary:
333MHz chips have a faster FSB from chip to components, but slower from memory to components.
266MHz chips have a slower FSB from chip to components, but faster from memory components.
This assumes you're using the fastest possible RAM with your board, and <b>not overclocking</b>. If you overclock, you can get damn near any FSB and memory speed you want if your components are good. Does this make more sense?
//EDIT: For clarity.
Agreed.
This right here.
Edit: Or I guess get some DDR2 1066 and run it at 1000 with the 3:2 divider?
Look at the overclocks for my Q6600 systems in my signature. All the DRAM I'm running is PC2 6400 (DDR2 800). I've got it running at speeds ranging from 800 to close to 900. Some of it, I'm sure, will run at higher frequencies, but I just haven't experimented in that range yet. The A-Data I have won't overclock much at all.
(oops, the multiplier/FSB settings in signature may not be up to date - I'll check when I get home this evening)
It seems odd to pay more for "quality" slower RAM just so that I can overclock it to speeds that other faster cheap RAM is rated at to begin with. For example, if 2x1 GB of cheap DDR2 800 is $45 and 2x1 GB of cheap DDR2 1066 is $80, should I pay $80 for 2x1 GB of higher quality DDR2 800 just because it will be more likely to overclock to 1066?
To clarify, you don't need Ballistix or OCZ Reaper edition or anything every time, but the middle-tier brands are stronger in my experience than the bottom tier, and to me, middle-top tier 800 is a stronger option to me than lower-tier 1066.
BTW, the RAM that people tend to have the most problems with is the higher quality OCZ. Often, the motherboard default RAM voltages are lower than the specified minimum voltages for the RAM. That's not a fault with OCZ, it's just the way it's designed. But then, this is not a problem if the user increases the voltage before installing the RAM.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820134586
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
The only reason I usually pay more for RAM is to get tighter timings which doesn't seem to be much of an issue with this high speed DDR2.
Exactly! You would most likely benefit from 4GBs of ddr2 800 over the 2 GB of ddr2 1066. I have run corsair dominator 1066 at both 1066 and 1800 speeds, and would not have been able to tell the difference if I didn't have 3dmark saying "HEY you got a better score". Having decent ram in a larger quantity seems like the better option for the long run than top of the line ram in a smaller quantity, and if you feel like tweaking some stuff, there are options out there that will grant you that ability. Out of all the components that a consumer has to choose from when building a PC, I think ram is the hardest to choose.
