"Missing NTLDR fix" problem.....Help...Thrax or anyone
adarryl
No Man Stands So Tall As When He Stoops To Help a Child. Icrontian
Buddy of mine tried to help a friend with a missing NTLDR issue and I put him on to Thrax's artice: "Repairing Windows XP in Eight Commands." However, he booboo'd and just emailed me for help. Here is his email to me:
"Darryl--
I went to the site you suggested-- http://icrontic.com/articles/repair_windows_xp -- and started to go through the process.
Everything was going well untill I accidentally hit the enter key without first hitting the Y key after the question
"Add installation to boot list?"
Then nothing happened, so I typed in y AND ENTER. again, nothing happened so I typed in "exit " and shut down.
Attempting to repeat the process, I now get a prompt that the file cannot be found when I enter
"ATTRIB -H C:BOOT.INI
Any suggestions?
The XP disk I am using to get to the repair console is an XP Professional, DELL disk. It says I can install XP Pro. Is that an option for me, or would it further screw things up since this is a Compaq with XP Home Edition? I can get some installation keys from any of the Dells we have using this same edition of XP.
If I simply install XP Professional, do I choose
C: Partition1 [NTFS]
or
D: Partition2 (SYSTEM_SAVE) [FAT32]
Will appreciate any advice."
Can anyone or you, Thrax, point my pal toward a fix? Thanks!
"Darryl--
Any suggestions?
or
