help
k guys I think my asus a7n8x bit the dust. I had a 2500 barton on it but its looks okay and is in my spare system now. Im getting some christmas cash like $250, should I get another mobo. Or should i sell my barton and get a p4 or amd 64 setup (ex amd 64 3000+)give me some input guys
Much safer is to order a replacement bios chip. The drawback here is that if it doesn't help you are out $10 - $20 bucks for the chip.
Another idea would be to order an identical board and borrow the chip to test the dead board. If it works, you can then order a replacement bios chip. This would leave you with a fully functional spare MB which you could keep for a backup, or sell to recoup some of your dough.
Good Luck!
If not, go to www.badflash.com
There is also this company which some of the other members have used with good results.
Keep in mind though, that until you try it you can't be sure that it even is the bios.
try removing the board from the case and put it on an NON-conductive surface
static bages outside IS conductive so use eather wood or cardboard
It required a hotflash to get it back.
Thrax you the man
But I wholeheartedly agree that paying for something you are entitled to get at no charge is nuts.
