Problems running 2 250gb hard drives with xp pro?
I'm gearing up for the boxing day sales and am hoping to get a pair of WD 250GB se's for cheap tomorrow or the day after.
I'm going to be running them off a promise ata card that they say will support LBA 48bit larger than 137gb as long as I have the newest bios for the card, which is not a problem to do, it's more so windows that I'm concerned with.
Xp pro, with SP1. Any problem getting it to see the full capacity of the 2 drives?
I've got 4 160GB hard drives in my dual 2500 system, and they're in 2, 2-drive RAID 0 arrays; each array has a formatted capacity of ~310GB, and Win XP sees all 310GB just fine.
What kind of performance? My 160GB Maxtor (DMax 9s, ATA-133/7200RPM/8MB on SATA adapters) arrays hit >100MB/s sustained reads and writes in ATTO.
I think half the members of S-M are turning green with envy right now!
However, I'm happy with my HighPoint RocketRaid 1540.
If it's ok with you, I'd like to leech some info from you
I'm considering getting 2x ~37gb Wd Raptors soon. I know my mobo will support it, and my psu has 2 Sata connectors. Currently I'm using those 2 WD's in my sig, in no particular raid setup.
How should I go about connecting the raptors, considering my mobo? I'd like to install Windows XP Pro (and later SP1) on it, and I was wondering if the setup of XP is any different - i.e hitting function keys and so on?
The reason I'm asking, is because I don't know much on this topic, and I'd really hate to trash my entire setup simply because I gave raid arrays a go.
If I were to get 2 extra ide drives (different size compared to my 120gb WD's) in the future, will this mess up my raid setup?
Yes, you can add IDE drives later without affecting your RAID array. Assuming, that is, you're just running them as 'normal' IDE drives on the PCI bus. Or a third party controller I suppose.
They were $376 each after tax but before rebate in Canadian $$, then throw in a $100 US mail in rebate, and that's ~$230 or so each. I couldn't argue. now I can sell off my mass of smaller 40-80gb drives and just run a couple of large ones.
ginipig, my Raptor has both connectors, the legacy one and the new style, unlike the seagate ones that only have the new style.
Well, I did a quick search on a7n8x-deluxe + raid arrays, and it seems that a lot of people have had trouble with converters.
Results: RocketRAID404, Raptors (using onboard) with OS, and PATA for misc (using controller).
And in response to raid cards, I picked mine up for $13 off ebay. The setup was different than I expected but worked wonderfully nonetheless. I could not, for the life of me, press F6 during Setup. I had to continue into the setup until it asked me for a mass storage device driver (or something similar to that) then I threw in the floppy disk I had to make (it only came with a CD). But, I can't complain with the card.
I've got a pair of Maxtor Diamondmax9 250GB SATA drives running off of a RAID_1 mirrored partition on my Highpoint 1540 RocketRAID PCI card. I'm not sure if my sig is up to date so here it is just in case:
2 x AMD Opteron 248 (2.2GHz)
MSI K8T Master2-FAR / Award v1.1 BIOS
2 GB of TwinX1024RE-3200LLPT (4 x 512MB)
2 x 74GB WD Raptor (*XP boot* RAID_0 on VT8237)
Highpoint RocketRAID 1540 PCI card
2 x 250GB Maxtor Diamondmax9 (RAID_1 on HPT1540)
80GB Western Digital (*SuSE boot* IDE2 port)
Sapphire Atlantis Radeon 9700 128MB (AGP 8x)
Enermax EG651P-VEFM (550W 24-pin ATX PSU)
Lian-Li PC-69 Aluminum Mid-Tower Case
WinXP SP2 and all critical updates
Whenver I try to transfer data to the HPT1540 RAID_1 partition XP freezes up on me. I've tried reinstalling/updating the drivers, reinstalling XP proper, repartitioning the drives - I've even run memtest86+ on my DDR, but no luck.
I've had the partition up for awhile but I haven't really been using it since I was waiting until I had SuSE running to format it FAT32 (so both XP and Linux can access it) however in trying to narrow the breadth of this problem I've since formated the 80GB SuSE partition (Linux is no longer on my desktop - I did this when I decided to reinstall XP).
Any ideas as to what might be the problem?
I made it 99% of the way through a re-format (full, not quick) in XP, but I made the mistake of backgrounding it and playing an mpeg - the moment I started this everything froze up. Prior to this, whenever I tried to copy any remotely sizeable chunk of data (say 500+ MBs) XP would freeze regardless if I was doing anything.
HELP!!!
please?
