Problems backing up drive - prior to drive upgrade
Hi there - I have a dell C640 laptop with a hard drive that is beginning to show a couple of data errors here and there. The system still runs quite well. I have a new 2.5" drive to replace it, and am trying to first do an image or backup on the installed drive. I understand some of the data on this drive will be corrupted. I already have all of my documents and personal information copied to an external drive, so that is 'safe', as safe is. What I am trying to do now is image or backup the system and installed programs so I can bring that over to the new drive. I'd like to avoid reinstalling all of that by hand.
This morning I have attempted to do a Microsoft backup and it is not able to complete and provides the following report info (below). Clearly, this is not going to work, unless you have some suggestions. Are there some disk repairs tools I can use to 'mend' and mitigate the issues? should I run diskcheck, or try to use diskpatch (recovery), or???? I also have acronis and can boot that from the CD. I tried to image the C drive but it was unable to read some sectors. I chose ignore all, but it appeared to get hung up (although I may try it again and let it run overnite). My thinking is if I can get this system over to a new drive, can some repairs be done to the system such that the system becomes healthy again?
===MICROSOFT BACKUP REPORT============
Operation: Backup
Active backup destination: File
Media name: "2-14p-2009 ASR C640 Backup.bkf created 2/15/2009 at 11:25 AM"
Backup Type: Normal
Backup started on 2/15/2009 at 11:25 AM.
Error: Could not access portions of directory System State\COM+ Class Registration Database.
You may not have permission to open the file, or the directory may be missing or damaged. Please contact the owner or administrator.
Error: Could not access portions of directory System State\Registry.
Backup completed on 2/15/2009 at 11:34 AM.
Directories: 173
Files: 2778
Bytes: 512,676,300
Time: 8 minutes and 23 seconds
Critical files that make up System State were not successfuly backed up.
Restoring this backup set will cause system failure.
The operation did not successfully complete.
Operation: Backup
Backup Type: Normal
Directories: 173
Files: 2778
Bytes: 512,676,300
Leonardo, or anyone who has some thoughts, I ran Seagate disk tools for Windows on this drive, and it failed. No surprise. Since my goal here is to try to transfer the system and programs from this drive to my new drvie, as a last step or two, I could try one of the following:
- run seagate disk tools from DOS since it has the ability to do sector repair
- run chkdsk (not sure of the / options on this command)
- run some sort of sector data recovery tool like diskpatch
any thoughts?
I can't help you with data salvage, but there are some others here are knowledgeable.
