XP detecting TWO 9800 PRO cards, AGP speed set to 0 – need help!
I just got my Sapphire RADEON 9800 PRO ATLANTIS.
Previously I had GF4 Ti4200.
I uninstalled nVidia drivers, took Ti4200 out, put 9800 PRO in, booted up…
Here’s where the problems began.
Any ideas?? :confused2 :confused2 :confused2
Please help!
Thanks.
- Problem 1:
For some reason Win XP keeps detecting two video adapters
I then installed latest Catalyst drivers (4.1 I think) and no matter what I do system still thinks I got two video adapters.
If I delete/uninstall it from Device manager it will re-detect it again (Found New Hardware dialog)
The only thing I was able to do is Disable one of them in Device manager. - Problem 2:
My AGP speed is set to 0 and I can’t seem to be able to change it.
CATALYST has a tab where you can alter AGP speed, then it reboots and determines what’s the max safe AGP speed (and reverts to it)
Well I tried setting 4X (which is what I think my AGP port is capable off – according to Sandra program anyway).
After I rebooted it was set back to 0.
Please help!
Thanks.
I just don’t understand why Windows XP detects 2 cards?
Also I used Driver Cleaner to clean the drivers, is that the same thing as detonator destroyer?
Anybody else?
Also, if you set your agp speed in your BIOS to 8x, it will prolly fix that other issue. (unless it already is set to 8x, then idk what to tell ya)
Yep, exactly!
Doh!
Do I feel stupid now. So I should leave the second one enable then, correct?
Thanks a bunch!!!!
I can’t find a setting for AGP in the bios
(I have DELL Demension 4500 series desktop)
DL and run that. Goto the mainboard tab and look at the AGP settings. If it says 8x, you are good to go!
Link doesn’t work
Thanks.
Just checked the link, works for me. *shrug*
Dell Dimension 4500 series
P4 2.4GHz 512 cache 533Mhz bus
512 MB RAM (266 MHz – f**king Dell)
Sapphire RADEON 9800 PRO ATLANTIS 128MB
60Gig HD (ATA/100)
That’s all relevant info I can think of…
Croc,
Now it worked – weird
Thanks.
No actually the front bus is 333Mhz.
I thought I was getting 333Mhz ram as well (it was very misleading on DELL site
No the FSB (In Mhz) for your CPU is 133mhz. Pentium 4 are Quad pumped (Clock x4) ie. 133 x4 = 533. You may have DDR333 but it is only operating at DDR266 (DDR = Clock x2) speed.
You would need a dual channel capable mobo (i865PE or i875P chipset) with 2 matched sticks of memory (2 sticks of DDR266/333/400 ) for full P4 CPU/memory Bandwidth (2x DDR266 = P4 533)
Using Single channel DDR with a P4 cripples its performance.
It’s a free version, so it was the default (1024x768) mode.
I only got 2468, however I had my AA at 4x and AF at 8x (as usual)
Was I supposed to turn those OFF for the test or does it matter?
Thanks.
Usually its run with everything set to performance. you should try that, then try it set to balanced.
I'll re-try tonight again.
BTW: that proggie CPUZ shows the entire Mainboard tab greyed out.
I ran SANDRA and it shows my AGP as capable of 1x 2x and 4x, but says it's currently OFF/1x.
WTF?
