Is This a Power Supply Problem?
Ok... Im really angry right now so I don't know how this post will sound, hehe.
I just got my RMA back from Western Digital for a new WD800JB drive. It works fine and all is fine and dandy. I was trying to delete my partition on the old drive so I could send it back and had forgotten how to do it.
I finally got a copy of FDISK and put it on a floppy. I unhooked the new drive and hooked up the old one. I got rid of the partition using FDISK and then went back to putting my new drive back in.
I hooked everything back up and started my computer... It started to boot and go to the Intel P4 HT logo and then my rear fan (60mm which is hooked to my Nexus fan controller slowed... and turned off, but my 80MM TT Smart Fan 2 which is also connected to the controller went on full blast!... then my computer turned off. I tried to switch it back on and it wouldn't power on... I turned off the psu, then turned it back on and it booted, but now, the last 3-4 times Ive booted up, my fans start up fine but the one slows down and stops and the other goes on full blast... I have a Raidmax 350W psu and I'm powering the following...
All of the basic stuff... floppy, mobo (and all that needs power on that, CPU, Nbridge fan etc...) then I have my FX5900, 1 DVD-RW drive, 1 CD-RW drive, Dual CCFL's, and ... several fans (2 of which are connected to my Nexus NP201 which is also powered by the PSU (obviously).
Can someone honestly tell me if 350W is or isn't enough for all of this... I've had this setup running for about a month and a half now and it has done this several times but for the most part everything works fine...
I have no money atm... but my dad might pitch in and buy a psu but it can't be over 100 bucks... I have the option of CompUSA or Allied PSU's pretty much...
That being said:
350w would be sufficient if it were a decent power supply. Check the voltages with a multimeter and see what they're like.
Everything is fine for now so maybe I'll just get some quieter fans or ones that are manually controllable (like the Smart Fan 2).
Does anyone know of a good 60mm fan that is really quiet and maybe controllable???
You could build your own fan speed controller, or get a thermally controlled fan, though.
Thanks for the tips and such!
