Supplied by Cable-Safe
Look under your computer desk. There lay the spaghetti tangle of cables. It may only be power bar, monitor, modem, mouse and keyboard cables or it may be something more daunting. The clutter of cables under a PC desk has become somewhat of a fixture in our lives and it’s a mess that is usually ignored rather than dealt with.
Cable-Safe says otherwise. The Cable Manager and optional Expansion Kit solve the problem of the tangled weave of computer cables by lifting cables off the floor and organizing them into a tidy wall-mounted or desk-mounted caddy.
The starting point is the Cable Manager kit which can organize up to 12-14 cables, secure 3-4 small devices (such as an electrical power pack or router hub) and provide hangers for 1-2 power strips. Cable-Safe promises that a mess under a desk can go from this…
…to this .
That may be easy for 6 or 7 cables and a power strip but our challenge was a little bit more…overwhelming. One of the Short-Media main labs features 3 PCs with:
- 2 monitor power cables
- 2 VGA cables
- 1 mouse power pack
- 1 router power pack
- 1 modem power pack
- 3 PSU power cables
- 2 cable vision BnC cables
- Left and Right speaker wires
- Stereo patch cable (from sound card to stereo amplifier)
- 4 VGA-Mouse-Keyboard KVM cables
- 2 monitor VGA cables
- 4 Cat5 cables
- 1 printer USB cable
- 1 USB mouse cable
- 1 USB keyboard cable
- 1 rather large power bar
That’s nearly 30 cables shoved under the desk and, till this moment, shamefully ignored.
It’s embarrassing to admit this monstrosity lurks under the desk collecting cobwebs and dustbunnies. Three to four times the usual amount of cables would test the capacity of the Cable-Safe Cable Manager.
What’s in the box
The Cable Manager kit is simple to assemble and install. The kit contains:
- 1 DeskClamp
- 1 CableTrack
- 3 CableHooks
- 18 CableStraps
- 1 Cable Label Sheet
- 4 Cable Guides
- 3 Bungee Straps
- 1 Alcohol Pad
- 4 Screws
- 1 Instruction Sheet
The three cable hooks (left side of the following image and shown in the upside down configuration) clip into the rectangular bracket. The bracket can be screwed to a wall or desk. It can also clip into the stanchion bracket which can clip onto an desk edge, cable grommet hole or also be screwed to the underside of a desk. The rectangular bracket can clip to either side of the stanchion bracket.
The cable hooks easily clip into one of four four areas on the rectangular bracket. The cable hooks can be positioned anywhere along the one of the four 2 and a quarter inch tracks. Note that the “hooks” of the cable hooks are to be on the lower side of the cable hook post. The flat “upper” surface provides the resting place for any external devices.
The stanchion jaws are padded to protect the desk. The orange lever is in the locked position in the following image. The lever, when flipped from open (down) to closed (up), tightens the jaws to secure the stanchion to a desk. (6 following images courtesy of Cable-Safe website)
There are a few configurations depending on the organization task at hand.
The rectangular bracket can also be screwed directly to a vertical surface such as a wall.
The entire process is supposed to progress like the following animation courtesy of the Cable-Safe website.
Cable-Safe also includes basic instructions and color/pattern coded labels.
There are three self-adhesive sticker that are pattern and color coded to dot stickers (under the port labels column in the following image). The stickers are to wrap around the cables and the dots affix next to where the cable is to be plugged in. Hooking up a PC may be simple to hook up for some but it can be confusing for the inexperienced. Stickers and labels make it that much easier. The label sheet should be kept as it has a label key that should be filled in when labeling all the cables and ports.
The kit also comes with accessory parts including 18 x 8-inch Velcro strips on a perforated roll, 4 self-adhesive cable guides, 1 alcohol pad for cleaning mounting surfaces or cables, 4 screws, and 3 bungee cords. The velcro straps have a hole at one end to “tie” around a cable.
The Expansion Pack adds a second rectangular bracket, 2 more cable hooks and the same accessory pack including a label sheet and instructions.
Did it work?
Nearly 30 cables makes for a large cleanup job and this is far more than the task of cleaning up 6-7 cables of a single PC system. Recapping the job at hand is the task of cleaning up one of the Short-Media main labs features 3 PCs with:
- 2 VGA cables
- 4 Cat5 cables
- 1 USB mouse cable
The entire job of installing the Cable-Safe Cable Manager and organizing the computer cables will only take 15 minutes to an hour depending on the amount of cables. A novice should use the labels and corresponding dots before disconnecting the system. Begin by labeling all the cables (optional) then disconnect everything to unravel the rat’s nest.
It may take a bit of crawling around under the desk but it’s worth it.
Finding the optimum position to mount the Cable Manager takes a few tries but the quick disconnect lever makes it easy. A hint for determining how to loop cables properly is to begin by taking a straight line from the either end of a cable to the cable hook. This will determine how you best loop the remaining slack to then wrap with the included velcro ties. Again it’s a matter of a couple of dry run-through’s to get it to what suits a particular setup.
All in all the Cable Manager will vastly improve cable management.
A look up and under reveals that even the mess of nearly 30 cables can be organized although achieving what the Cable-Safe website shows may not always be possible. Their images have been painstakingly arranged to best present the product.
Mounting the power bar is far easier with a power bar that has a end mounted cord rather than a side mounted cord. The Cable Manager is rated for up to 10 pounds which is a fair amount of weight. It’s best to configure it to what suits the environment. If access is needed to the power bar or it’s better suited on the floor…then leave it as is and use the velcro ties to tidy up the bundle of power cables.
The chore of bringing organization to a vast amount of cables was easily handled with the Cable Manager kit. The Expansion Pack would come in handy if more equipment, such as the modem and router, were to be moved under the desk. The Expansion Pack will not go unused though. It will be attached to the wall behind the stereo unit (on the brown 2 drawer unit at the left of the preceding image) to manage the stereo, printer, light and coffee cup warmer cables.
Cable Safe state that the secret to perfect loop cables is
When we wrap the cables we first drape the cable over a hook. Then
pulling down to straighten the cable, we form equal length loops using
the hook and our hand to set the length. It’s a lot like wrapping an
extension cord over the palm of your hand and around your elbow. These
loops are then tied in two places at both the top and bottom of the
loops.
Someone could run off to a neighborhood hardware store to pick up velcro and materials to construct their own cable manager but it would probably cost about the same (or more), be much larger and less versatile.
The Cable-Safe Cable Manager and Expansion Kit brought order to the chaos under the desk. The Cable Manager is a simple idea done well. For years people have put up with the clutter under a PC desk and the Cable Manager is a great solution.
Our thanks to Cable-Safe for
their support of this and many other sites. The Cable Manager ($34.95 USD) or Expansion Pack ($22.95 USD) can be ordered in the US from the Cable-Safe website or from NCIX in Canada for only $38.83 CAD.
Ratings breakdown
Only the Cable Manager was rated as a base though the Expansion Kit was included in the review.
Highs
- Organization is good.
Lows
- You have to do what you’ve been putting off.
Attribute | Score | Comments |
Design & layout | 9 | A simple goal of organization executed well. |
Documentation | 9.5 | Simple and easy to understand instructions. |
Fine-tuning features | 9 | Highly configurable. |
Performance & stability | 9 | Secure clamping device and weight of cables is held well. |
Presentation | 9 | From a marketer’s point of view…the box does a very good job of selling the product. |
Price / value | 9.5 | I challenge you to find another PC product under $40 that solves a problem, is high configurable, organizes and improves aesthetics. |
Total score | 55/60 | 91.7% |
