NZXT has a history of pushing PC case design—if not from an aesthetic perspective, at least from the quality and features end of things. NZXT’s aesthetic design choices are sometimes downright divisive, but their brand is undeniably recognizable and consistent.
They won a lot of accolades for last year’s Switch 810, which used to be their biggest, boldest case. No longer. The Phantom 820 now takes that spot. It is a little bit taller and deeper than the Switch 810:
The Phantom 820 retains NZXT’s Phantom design language with its angular surfaces, but has improved over its predecessors in almost every way.
Specifications
| MODEL | Phantom 820 |
| CASE TYPE | Full Tower |
| FRONT PANEL MATERIAL | Plastic/Steel |
| DIMENSIONS (W x H x D) | 235mm (W) x 650mm (H) x 612mm (D) |
| SPECIAL FEATURES | Integrated HUE LED lighting system, SD Card Reader, 4-channel 15-watt Fan Digital Controller |
| FAN CAPACITY | Top: 2x 200mm (One included) or 2x 140mm or 3x 120mm Front: 1x 200mm (Included) Bottom: 2x 140mm or 2x 120mm Rear: 1x 140mm (included) or 1x 120mm height adjustable Side: 1x 200mm (included) Pivot: 1x 140mm or 1x 120mm internal pivot fan |
| RADIATOR CAPACITY | Top: 2x 140mm or 3x 120mm Rear: 1x 140mm or 1x 120mm Bottom: 2x 140mm or 2x 120mm Pivot: 1x 140mm or 1x 120mm |
| DRIVE BAYS | 4 EXTERNAL 5.25″ DRIVE BAYS 6 INTERNAL 3.5″ DRIVE BAYS Screwless Rail Design |
| MATERIAL(S) | Steel, Plastic |
| EXPANSION SLOTS | 9 |
| WEIGHT | 15kg, 32lbs |
| MOTHERBOARD SUPPORT | E-ATX, XL-ATX, ATX, MICRO-ATX, Mini-ITX |
This is about as big as it gets for a “normal” enthusiast PC case. If you can’t fit your multiple GPUs, multiple drives, and giant watercooling setup in here, you’re probably doing it wrong.
The Phantom 820 comes with a separate case of screws and accessories as well, with individual compartments for each type of screw—a very nice feature.
Details
Details are where NZXT has always excelled, and the Phantom 820 is the pinnacle of attention to detail in their case lineup. The integrated HUE lighting system is gorgeous; it disappears when off, and when it’s on, the translucent rails where the light is seen are in aesthetically awesome places. The buttons all have a high level of fit and finish, and do not feel cheap or easily breakable like so many other cases. The inside maintains the high level of quality that I’ve come to expect from NZXT; from the motherboard tray area, to the massive CPU cutout, to the endless options for cable management.
One of the best features of the Phantom 82o are the included fans; three massive 200mm 800rpm fans are included, and just on their own serve to move enough air around (silently) to cool any normal system. They also include a 140mm rear fan, and all of these are hooked up to an integrated NZXT fan controller that is easily accessible from the top control panel.
Building
I’ve said it before, and I mean it: building a PC into an NZXT case is a dream. It doesn’t really get much smoother or easier than putting a system into this case. There’s more room than you need, there are cutouts exactly where you want and need them to be, there are labels when you need them and clean surfaces with no markings when you don’t. Cable management is simple and there is a ton of room in the back of the motherboard tray for any possible cables you could ever try to cram back there. It’s entirely possible to make a completely clean, “wireless-looking” build with the Phantom 820.
The only problem I encountered was with the hard drive trays; they were just slightly too thick to accommodate a normal hard drive mounting screw. As you can see in the picture below, the screw barely reaches all the way through the tray:
I had to really squeeze tightly to have enough screw come through to “grab” onto the SSD. I definitely made it work, but the effort involved was more substantial than every other part of building into this case, so it was notable. And yes, I tried every supplied screw. This was really a very minor problem, but when you have something that is so good and so easy to work with, the little tiny problems tend to stick out more.
The fan controller and HUE lighting system are already installed and working out of the box. All you need to do is plug the side fan into one of the controller leads and you’re set. NZXT (as always) gives you tons of extra length on case leads, so no matter what motherboard you have or where the headers are, you will not have any problems plugging things in.
The removable HD tray mechanisms are all extremely well-engineered and do not have any fit problems. They slide in and out very substantially and lock tightly in to place.
One of the standout features of the Phantom 820 is the giant space you have available for radiator installation on top. There is room for large radiators on top or on the bottom (for example, the NZXT Kraken X60 will fit on top or bottom), while still leaving plenty of room for tube management and aesthetic features. Here’s a press shot from NZXT showing some of the possibilities with multiple radiators and custom watercooling setups:
Value
This is not a cheap case. It is $250, and at that price it is going to be one of the most expensive parts of your PC. However, it doesn’t really get more future-proof than this as far as enclosures go. You’ll be able to build your next several system cycles into this case, and with the high standard of build quality, it will last.
Aesthetics are a much more divisive element. Many people will not like the aesthetics of this case and will prefer the clean, flat surfaces of the Switch 810. The Phantom design is controversial; many users disagree with the choice of a side window, or with a non-flat top, or the angular front panel.
It’s also very heavy. At 32 pounds unloaded, you’re looking at a system that may weigh almost 50lbs with a bunch of stuff in there. This is not exactly portable, and makes travel for LAN parties a challenge. However, the reason it’s heavy is because it’s mostly steel and it’s built very well. You can’t have one without the other.
The NZXT Phantom 820 is a flagship in every sense of the word. It’s big, it’s heavy, it’s extraordinarily well built, and it’s bold. It screams “I’m a custom computer builder and I love my PC” when it’s all lit up and whirring away. Everybody that has seen it at IcronticHQ has commented on its size or sheer spectacle, though it maintains a classy look.
From a features and performance perspective, this is easily the best full-tower case NZXT has ever released. Of course, case aesthetics are important and so some people will be turned off by the look, particularly older or married PC builders who have to deal with SAF (Spouse Acceptance Factor). At this size, it becomes almost a piece of furniture, and so fitting in with the rest of the room is something to consider.
Regardless of how you feel about the aesthetics, the features are spot-on, and the quality is tremendous. I am happy to award the NZXT Phantom 820 our silver Outstanding Product Award for exceptional attention to detail and for being the most feature-laden case I’ve ever reviewed.
The NZXT Phantom 820 is available in three colors: Black, White, and Gunmetal. It is available for $249.99 at Newegg.com and other retailers.
