MSI K8N Neo Platinum NF3-250GB Motherboard Review (FSB 246mhz Overclock!)
Anandtech reviews the MSI K8N Neo Platinum NF3-250GB Motherboard and OC’s it to [b]246MHZ[/b] (& higher).
This late 3200+ achieved a new overclocking record on the K8N Neo Platinum at [b]246FSB[/b], at the stock 10X multiplier and default voltage. This 23% overclock at stock multiplier is more like those that we are accustomed to seeing on Pentium 4. [b]Dropping the multiplier, the highest FSB overclock that we could achieve was the BIOS limit of 300[/b]. We fully expect that the K8N can go much higher on FSB, but Clock Gen for the nForce3-150 from www.cpuid.com only partially works on the 250 chipset.
Source: Anandtech
