Radeon 9800 Pro Warning
Guru3D reports some interesting info about a cheap version of the Radeon 9800 Pro ATI graphics card that is apparently doing the rounds at the moment. Check it out.
I was just checking our forums and noticed that people are able to buy a Radeon 9800 Pro in the 170-180 USD range, and they have no clue why the card was so cheap. Fantastic price, yet a way too low price. It’s a Radeon 9800 pro alright, yet equipped with 128-bit memory where it should be 256-bit. Basically frame buffer bandwidth is cut in half and despite full eight pipes it’s placing itself in the mid-range segment as core and memory clocks are lowered also. This will have a serious effect on overall performance. Take a Suzuki Hayabusa motor cycle which can do like 300 KPH yet it is forced to drive on a small road where it will never exceed 100 KPH. Look at the Suzuki as the Radeon 9800 Pro and the road the memory bandwidth.
Source: Guru3D
  1. entropy
    entropy oh god ... is there a way to verfiy you have 256 bit memory? i bought my 9800 pro from buyxtremegear (NO ONE EVERY BUY THERE, IT'S CRAP) but mine said ATi, and it has a silver heatsink ... so is there a test or some program that can tell you?
  2. entropy
    entropy Dzhedaj
    Member Guru
    The 128bit version uses different memory (called BGA I think)
    The memory is not square but the size ratio is rather 1x2. I think that's the only visual difference...Some of them use different heatsinks, but that depends on the company selling the card....
    i saw this posted on the guru3d site's comments on this article ... can anyone verify this?
  3. Mt_Goat
    Mt_Goat The 128 bit version is being sold everywhere, including Newegg. They have a Saphire 128 bit but if you read all of the print you will see it.
  4. hooj
    hooj This was taken from www.scan.co.uk
    You can tell if a 9800 has 128bit interface by the memory chip configuration on the PCD. If they are in a straight line (looks like a 9500 Pro) its 128bit. If its a 256bit card, the memory has an 'L' shape configuration, 2 along the side & 2 along the back.
  5. kanezfan
    kanezfan a lot of the 9500 pros had L shape configuration too
  6. entropy
    entropy yep, mine are square shaped memory blocks, and they are in L configuration .. whew ... i thought i was getting screwed for a minute there lol
  7. EyesOnly
    EyesOnly My 9800 pro is a 128 mb but i know that. If i would have gotten the 256 version it would have costed as much as a x800. BTW mine's a saphire so i know it's good. What's so wrong with the 128 mb version.
  8. TheBaron
    TheBaron no no no they aren't talking about the 128 MB vs 256 MB versions, they're talking about the 128-bit vs the 256-bit versions.
    for example, if i bought a 128-bit 128mb 9800 pro it would be about half as fast as a 256-bit 128mb 9800 pro, because the memory bandwidth has been cut in half
  9. Omega65
    Omega65 Basically it's an updated 9500Pro card. As the original 9500Pro was a 128bit version of the 9700Pro.
