Though Intel has been promoting the spec for a while, the company only recently rolled out its first retail BTX boards.
Intel’s new BTX (Balanced Technology Extended) specification gives motherboards a makeover. The company says that the new motherboard and chassis spec uses fewer fans, resulting in PCs that run more quietly, and possibly at a lower temperature, than those based on the aging ATX (Advanced Technology Extended) standard found in most of today’s PCs. To that end, BTX boards sport significant changes in component layout and thermal engineering.
Though Intel has been promoting the spec for a while, the company only recently rolled out its first retail BTX boards. It expects to offer three variants (all 10.5 inches long): standard BTX, with seven or fewer PCI Express slots (up to 12.8 inches wide each); MicroBTX (pictured, up to 10.3 inches wide), with four or fewer slots; and PicoBTX, with one slot (up to 7.9 inches wide).
Intel’s first two boards are both MicroBTX models; the chip maker has begun shipping CPUs with the Type I BTX Thermal Module (which replaces the traditional heat sink and fan combination), too. Companies such as AOpen have begun to offer BTX-based chassis, since you can’t place a BTX motherboard and Thermal Module in an ATX case. Expect standard BTX and PicoBTX boards to emerge sometime this year.
Source: PC World
