Corsair x Asetek H50 water cooler
Corsair hooked up with Asetek to make the H50 all-in-one water cooler. Looks like a contender to fight the CoolIT Domino ALC.
  1. BuddyJ
    BuddyJ Hexus has shots of the included kit. Looks like it'll have an easily swapped radiator fan. http://www.hexus.net/content/item.php?item=18619&page=3
    I think this unit hast two things going for it. 1) It should have less compatibility problems fitting in cases where the Domino ALC fails due to its pump/lcd unit having clearance issues, and 2) the bare copper base is probably a better conductor of heat than the Domino's nickel-plated one. It should also mount easier by the looks of things.
  2. BuddyJ
    BuddyJ The reviews are out. Hexus gives it a solid 80 percent rating. http://www.hexus.net/content/item.php?item=19073
  3. BuddyJ
