A couple weeks ago I spent a large amount of time with the nice people from NVIDIA at their SIGGRAPH booth. They were kind enough to indulge me in answering a couple of questions about their Tesla technology and a bit about what they have in store for the future.
Tesla is essentially a high-end workstation GPU with all of its video ports and drawing responsibilities stripped off of it. This might sound a little odd, but unhooking the card from its drawing responsibilities gives you nearly 500 cores with nothing to do but crunch numbers. These cores are then multi-threaded out to equal nearly 5000 cores. Hook that to their top-end workstation GPU, the NVIDIA Quadro 6000, and what you have is extremely precise computational potential at a blazing hot speed.
Tesla specs
| Tesla C2070 | Tesla C2050 | |
| Peak double precision floating point performance | 515 Gigaflops | 515 Gigaflops |
| Peak single precision floating point performance | 1030 Gigaflops | 1030 Gigaflops |
| CUDA cores | 448 | 448 |
| Memory size (GDDR5) | 6 GigaBytes | 3 GigaBytes |
| Memory bandwidth *(ECC off) | 144 GBytes/sec | 144 GBytes/sec |
| Display support | Dual-link DVI-I Max display resolution @ 60 Hz: 2560×1600 |
Why would you want this, though? This is not a setup for everyday computer users and gamers, that’s for certain. In gaming, things are happening so fast, you only need an overall sense of “pretty.” By pretty, I mean as long as everything looks alright on your monitor, everything is going well. If your GPU is botching a pixel here or there, no big deal. You can still get the frag.
However, when working with extremely precise dynamic particles or biochemistry simulations, you can’t settle for “pretty.” Everything has to be dead-on accurate. This is where a Tesla and Quadro solution can really shine—particularly if you need to be working in real time.
The question of multiple monitors
Tactfully, mind you, I also asked the following: “What if I would like a three monitor setup?” The response was that NVIDIA has found that, for most people, workflow is optimized with a two-monitor setup. At any given point one tends to be ignoring the third monitor. They did, however, hint they have a multi-monitor graphic solution in the works that blows anything existing out of the water.
For more on the Tesla, you can read up at NVIDIA.
