Today NZXT unveiled the FS-200 series of LED fans, available in red, green, and blue.
Of course, not every case can accommodate a 200mm fan, but—and this may come as a shock to you—several NZXT cases can indeed handle these gentle giants, including their flagship Phantom.
200mm fans are almost completely silent, so if you can handle the size and want a sweet looking, light-up fan for your custom build, these might be up your alley.
Specifications:
• Size: 200 x 200 x 30 mm
• Voltage: 12V DC
• Current: 0.42A+10%
• Input: 5.04W
• Speed: 700 rpm ± 200
• Air Flow: 89.5 CFM
• Air Pressure: 0.98mm H2O
• Noise: 20.16 dBA
• Bearing: Rifle Bearing
• Life: 40,000 hours
They’ll be available in mid-May for around $18.
