Power Supplies: The shocking truth!
Why you should consider it: How much power a computer requires is a complicated question that everyone wants a simple answer to. Five years ago the simple answer would have been “anything over 250 watts”. Today’s answer may more appropriately be “300 watts is minimum while 350 is safer but 400 watts would be an even better choice”. The simple answer changes as technology changes but one rule of thumb that hasn’t changed is not to “cheap out” on the power supply.
When was the last time you looked at a power supply in the computer case? Have
you recently bought a power supply smug in the knowledge that “you’ve bought
the best”? What if that expensive 400 Watt power supply…wasn’t? What’s
on the label isn’t necessarily what comes out the cable. Take a closer look
with us at power supply specifications and find out if you’ve really got the
power.
The PSU (Power Supply Unit), with its wires dangling like the legs of an octopus
that has been nailed to the inside roof of the pc case, either came with the
PC or it was an aftermarket choice after researching a forum or review. How
many of us really know what the power supply specifications mean, if specifications
are distorted and how that could affect the operational stability of a PC?
A power supply isn’t a top of mind concern for most. The computer turns on,
it works, it turns off. There’s no problem until there is a problem. Solution?
Pick up the phone and call that 24/7 support line. This is, of course, if you
knew that the power supply was the problem to begin with. Then there are those
who bought a PC from an OEM retailer to save a few bucks. The PC is packed up
and ferried down to the store and it is taken away and the power supply is replaced
with the same generic version or its cheap alternative that is presently in
stock.
Problem solved?
Go back to the symptoms. If the PC just shut down or wouldn’t power up and
there was an acrid smell in the air then the power supply most likely burnt
out. If the PC is unstable where it suddenly reboots or displays that pretty
Blue Screen of Death then the power supply may not be “up to the job”.
These instabilities are a common complaint. They often occur after upgrading
a processor, video card or adding another drive. If there is a stunned silence
and eyes are left blinking with the hanging question “how am I supposed
to know?” then the most simple solution is to upgrade to a beefier power
supply to handle the extra load. For overclockers and PC enthusiasts it isn’t
as simple as the decision to upgrade but what power supply to upgrade to? In
either case even a beefier power supply may still be the root of system instability.
Wattage isn’t everything and there is a way to make informed choices.
So how much power do you need?
changed is not to “cheap out” on the power supply. Cheap, generic,
bargain power supplies only lead to system instability. The “bargain”
power supply may be inadequate to supply the actual power that a computer draws
at certain voltages and/or amperages.
A few basic ground rules need to be set before getting “up close and personal”
with a power supply.
Zzzzzzzap!
First and foremost a power supply is an electrical device which, if not used
correctly, has the ability to damage components, cause bodily harm or even death.
Do not remove the cover or modify a power supply if not qualified to do so.
AC/DC
The power supply’s job is to take AC power (Alternating Current) and convert
it to DC (Direct Current) power. Unfortunately the computer power supply doesn’t
do a perfect job of conversion. In fact approximately one third of the AC power
coming into the power supply is wasted in the conversion process. This “wasted”
power takes the form of heat, which is exhausted by the power supply fan, and
as a high-frequency signal or ElectroMagnetic Interference (EMI). EMI is one
of the reasons why a power supply is contained within a metal casing. The metal
casing primarily prevents curious fingers from touching live electrical components
and thus possibly bbq’ing the owner of said fingers. Secondarily the metal casing
is a shield preventing those high-frequency signals from freely bouncing about
inside the PC case and possibly wreaking havoc with other electronic gizmos
and doodads that rely upon their own high-frequency signals to operate properly.
If the power supply were not shielded it would be like trying to listen to two
radio stations at once. The result would be a mish-mash of interference making
it impossible to make sense of either one.
Different Jolts for Different Folks
Power supplies also produce DC at different voltages to meet the requirements
of the particular component. In the most common power supply style, ATX, these
voltages have been been standardized.
Voltage Common Use
-12 Used on some serial port circuits. Not needed on newer systems and if
required on older systems is supplied at a very low amperage. <1A
-5 Was used by floppy controllers and ISA bus cards but now as common as
a Pentium 90 processor.
+3.3 Used by newer processors, AGP video cards, system ram and other motherboard
circuits
+5 Used on older motherboards to power components including the PSU. Manufacturers
are putting more emphasis on +3.3 and migrating away from +5 voltages. +5
is still used to power floppy drives and optical drives.
+12 Used to power disk drive motors in devices such as hard drives and motors
in optical drives.
Riding the Rails
Each of these voltage lines are also commonly referred to as “rails”.
A rail is defined as “either pole or conductor of a power supply, one is
positive and one is negative.” If someone asks “what’s the five volt
rail?” then they are referring to a voltage that a meter or software program
would show in reference to the amount of voltage output on the designated five
volt line.
Efficiency Rating
An interesting specification in a power supply is the efficiency rating. This
rating takes the form of a percentage and is a measure of the power supply’s
ability to convert AC to DC. A power supply that has a 50% efficiency rating
will only convert half of the AC input power into DC while the other 50% is
byproduct produced in the form of heat and EMI. Higher efficiency numbers are
better. The efficiency number will affect the power bill at the end of the month.
A less efficient power supply can waste AC like my V8 truck goes through gas.
PFC is not Private First Class
The use of “PFC” in a power supply’s description may be confused
with the term “Power Factor”. Explaining power factor isn’t that easy
but it is defined as the ratio of real power to apparent power.
Real Power: In alternating-current power transmission and distribution,
the product of the rms voltage and amperage, i.e., the apparent power, multiplied
by the power factor, i.e., the cosine of the phase angle between the voltage
and the current. Note: Only effective power, i.e., the actual power delivered
to or consumed by the load, is expressed in watts. Apparent power is properly
expressed only in volt-amperes, never watts. Synonym true power.
Apparent power: In alternating-current power transmission and distribution,
the product of the rms voltage and amperage. Note 1: When the applied voltage
and the current are in phase with one another, the apparent power is equal
to the effective power, i.e., the real power delivered to or consumed by
the load. If the current lags or leads the applied voltage, the apparent
power is greater than the effective power. Note 2: Only effective power,
i.e., the real power delivered to or consumed by the load, is expressed
in watts. Apparent power is properly expressed only in volt-amperes, never
watts.
Source: Institute for Telecommunication Sciences. (ITS)
See what I mean? I “phased-out” too and it gets more complicated
from there. PFC means Power Factor Corrector which is a converter device that
precisely controls input current to match the waveshape of the input voltage.
In layman’s terms the PFC acts like a traffic cop. A power supply will do what
is asked of it; some more efficiently than others. If the PC components ask
for 100 watts of power then the power supply demands AC current from the wall
and converts it to the 100 watts required. An inefficient power supply can ask
for more AC than it needs. A PFC equipped power supply allegedly reduces this
by being more precise when asking for the AC current to convert to DC.
The utopian goal is to derive the greatest amount of usable power from the
least amount of input line current. A 100% efficient power supply would produce
no heat or EMI and convert 100% of the AC input to DC power. A PFC equipped
power supply may not affect the overall wattage performance but it allegedly
makes the power supply more efficient at managing a stage of converting AC into
DC and therefore reduce energy costs.
The Peak of Power
Power supplies can be rated with two wattage numbers; peak and continuous power.
The peak power rating is usually in parenthesis right behind the continuous
power rating number. During normal operation the power supply has been rated
to be able to deliver a specific wattage all the time. This is the continuous
power rating but the PC can be a power pig during startup. Components, such
as hard drives, can chew up a lot of power when coming up to speed. Have you
ever tried to push a car? It takes a lot of effort to start it rolling but it
gets easier afterwards. Power supplies can have a “peak” power rating
to accommodate for this spike. The power supply can sustain a higher wattage
for a short period of time. This short period of time may be less than a minute
but it is enough to “get the car rolling.”
Now that the basics are out of the way coming to the definitive conclusion
of how much power a PC uses requires a bit of detective work. The amount of
power that a component draws fluctuates over time. Not all components will ever
draw their peak and most certainly not every component will make this heavy
demand on the power supply simultaneously.
Stop!
It is important to understand two concepts before progressing any further.
First:
Watts = Volts x Amps
Power drawn by an electrical PC component is measured in watts which is an
expression of the product of volts and amps. A processor that draws 50 watts
can function at 25 AMPS on a 2 Volt line providing the manufacturer has engineered
it to be able to do so. Second:
Combined Wattage Rating
Power supply lines can be rated independent of each other or combined. Typically
ATX power supplies are rated with a maximum wattage for the +3.3 and +5 line
combined meaning that the total of both, no matter the ratio, cannot exceed
the designated rating. This is an extremely important number to note when looking
at power supplies. A manufacturer may even combine the +3.3, +5 and +12 line
and provide a maximum wattage rating but this is not as common.
Which more is better?
If wattage is the product of volts and amps then is it better to have more
volts or is it better to have more amps? A simple analogy would be that voltage
and amperage is like a dam across a river and water is electricity. As the water
begins to build up against the dam the pressure increases. This is voltage.
Now the dam opens a floodgate. The amount of water that is allowed through is
amperage. The more the floodgate is opened the more amperage there is.
Electrical gurus everywhere will most likely debate this point with a lot of
complicated math, talk of resistance loads and so forth. That’s the problem
with analogies. They are oversimplified but it serves the purpose well for basic
understanding. More voltage isn’t preferable to more amperage. More amperage
isn’t preferable to more voltage.
huh?
Yes it’s time for those two nebulous words we all love to hear; “it depends”.
In the most basic form adding loads to a single line is a sum of wattages. 4
devices requiring a constant 20 watts each will draw 80 watts. As long as the
line can deliver a minimum of 80 watts then there is no problem. It’s always
better to have a minimum of 1.5 times the wattage needed.
The biggest problem is if the sum of all wattages exceeds what the line can
supply. For amperage look to the device that requires the highest amperage and
not the sum of all amperages. The same again for voltage. On a 150 watt line
4 devices requiring a constant 40 watts would be a problem because a total of
160 watts is required; 10 more than is available. On that 150 watt line that
can supply a maximum of 30 amps then if 3 of those devices required 20 amps
each but one required 40 amps then the 40 amp device would be the problem. If
any one of those devices on the 12 volt, 150 watt, 30 amp line required 15 volts
there would be a problem again.
So the “it depends” depends on the load being put on the PSU on the
specific line or lines. Motherboards have built in power converters to switch,
for example, +3.3 and +5 volt power to a required CPU voltage such as 1.65 volts.
As voltage goes down the maximum amps supported by that line will go up. Again…the
product of volts and amps equals watts and as long as that math doesn’t exceed
the maximum rating for that line or the combined lines then all is relatively
well.
Plug in the amps
Amperage is another tricky devil that plays funny tricks on a computer. Devices
that operate at the same voltage input can operate on a line that has an amperage
rating sufficient to the device that has the single highest amperage requirement.
Device A requires 10 amps. Device B requires 20 amps and Device C requires
5 amps. Each device takes only what it needs and amperage is available current
but doesn’t mean the excess is forced down the device’s digital throat. Therefore
a 20 amp line will support all three devices PROVIDING there is sufficient wattage.
Remember that wattage is the sum of all totals of volts times amps. So if these
devices were 12 volts then:
Device A = 12 volts x 10 amps = 120 watts
Device B = 12 volts x 20 amps = 240 watts
Device C = 12 volts x 5 amps = 60 watts
A single 20 amp line that had a minimum wattage rating of 420 watts would be
needed. That’s the pure physics answer. Amperage needs to be added but voltage
does not for a series circuit on a single line and vice versa for parallel but
wattage is a sum in both situations. So if wattage is fixed then voltage can
be stepped down to increase amperage and vice versa but math is an unforgiving
beast. More voltage and more amperage cannot be demanded simultaneously if it
exceeds the maximum wattage rating.
The question probably remains “then how do I figure it all out?”
The answer is to go to electrical engineering school because it’s not that simple
but the lesson in all of this is a simple number that often isn’t on the power
supply label that can separate a good choice from a bad choice.
Adding it all up
Adding up power requirements in a PC is a game of cat and mouse. Sometimes
it isn’t easy to find this information. Sometimes all of it isn’t completely
available. But if precise power is the goal then it’s important to don your
Sherlock Holmes hat and cloak and begin the hunt. In the following example the
maximum demand during normal operation has been listed according to component.
These numbers will, of course, change during standby, lesser activity or idle
modes. These, but not all, numbers will also increase during overclocking. The
following example shows an example PC’s potential maximum power requirements
by component during 100% usage which would rarely, if at all, occur.
  AMPS Volts Watts Voltage lines
AMD
3200+ Processor
46.5 1.65 76.8 +3.3
ATI 9700 PRO ++++ 67.5 0.8 54 +3.3/+5
Maxtor
7200 RPM ATA/133 80 GB HDD*
0.858/0.662 5/12 4.29/7.944 +5/+12
Liteon 52x CDRW 1.5/1.5 5/12 7.5/18 +5/+12
Mitsumi
floppy drive
    3.9 +5
ADDA
31.4 CFM 28.3 dBA 80x80x25mm**
0.15 12 1.8 +12
Motherboard     20 all
RAM
1 x 256 MB
3.76 2.6 9.776 3.3
Chipset fan     1.5 +12
300mm Cold Cathode light 0.005 12*** 3.4 +12
Round
CCFL fan
(light + fan)
0.135 12 3.96 +12
Audio (Creative Labs Audigy with 1394) +++ 0.450 12 5.4 +12
  • * Seek time measurement 5V/12V rating draw.
  • ** 8 x fans inclusive of heatsink fan.
  • *** Output voltage of inverter:680vrms.
  • ++ OPERATING CURRENT: Four device bank interleaving READs
    (BL= 4) with auto
    precharge,tRC = minimum tRC allowed; tCK = tCK (MIN); Address and control
    inputs change only during Active, READ, or WRITE commands. 3,760 mA
  • +++ Creative Labs Sound Blaster® Audigy™ Audio
    with IEEE 1394
  • Power Consumption +12 V, nominal current 160 mA
  • Power Consumption – Vcc, nominal current 450 mA (voltage
    controlled current source)
  • Power Consumption -12 V, nominal current 50 mA
  • ++++ in
    AGP 8x mode 0.8v. AGP 4x mode = 1.5v or 0.8v.
Categorizing the components by amperage, voltage or wattage on each of the
lines may also reveal important information before choosing a power supply.
  3.3 Volt Line 5 Volt Line 12 Volt Line 3.3 Volt Line 5 Volt Line 12 Volt Line
  Amps Amps Amps Watts Watts Watts
AMD
3200+ Processor
(draws 1.65 Volts)
46.5     76.8
ATI 9700 PRO Video Card       53 1
Maxtor
  0.858 0.662   4.29 7.944
Liteon 52x CDRW   1.5 1.5   7.5 18
Mitsumi
floppy drive
        3.9
ADDA
(2 rear, 1 blowhole, 2 front intake) 80x80x25mm
    0.75     9
Motherboard           20
RAM
1 x 256 MB
3.76     1.8
Chipset fan           1.5
300mm Cold Cathode light     0.005     3.4
Round
CCFL fan
(light + fan x 2 side intake)
    0.135     3.4
Audio (Creative Labs Audigy with 1394) +++     0.45     5.4
Total 46.5 1.5 1.5 131.6 W 16.69 W 68.644 W
The totals when compared to power supply specifications may show, for example,
that peak wattage demands on the 12 volt line exceeds what the power supply
has been rated for. In the preceding example the total required maximum wattage
that could be required by the PC components is 216.934 Watts. Then why the need
for these 300, 400 and 500 Watt PSU behemoths? It appears that a 250 Watt power
supply could do just fine with a little under 35 Watts to spare.
Wattage isn’t everything and a look at the PSU label may save hours of grief
and frustration.
The astute may have noticed that the amperage totals are wrong. Remember that
lesser amperages can exist on lines with devices requiring higher amperages
as long as the wattage is sufficient for both. It is the device with the highest
amperage that sets the proverbial pace.
Watt’s on the label?
By now the head must be spinning with numbers and it seems that the truth about
power supplies is no closer; but it is. A label can tell a lot about a power
supply even if it doesn’t tell a lot. The following are the specifications for
an actual power supply rated at 420 Watts with a 520 Watt peak load. This is
what typically is printed on the label. The name brand and model number is irrelevant
for this example.
Volt line +3.3 +5 +12 -12 -5 +5 Vsb
Amps 26 42 18 1 0.8 2.5
Remember wattage is volts times amps.
Watts 85.8 210 216 12 4 12.5
Contrary to what might be assumed, the rated power or wattage the power supply
can provide is not the sum of all the wattages. Therefore:
85.8 + 210 + 216 + 12 + 4 + 12.5 does not equal 540.3
Watts.
This is because each line is not independent of the other for the maximum rated
output. Once the power supply is tested on multiple lines simultaneously the
maximum wattage is reduced accordingly. The maximum individual rated wattages
on the label can only be attained if ONLY the single line were drawn upon. The
full reasoning involves a lot of math and quoting of such things like OHMS LAW…take
my word for it. 540 Watts is a bit over the 420 Watt continuous power specification.
Wattages for the individual rails are indeed possible if only that line were
used but the PC doesn’t work that way.
Manufacturers supply combined ratings in addition
to the maximum rated output. A combined rating is the maximum wattage possible
of two or more lines drawn upon, each in any amount, simultaneously. This will
be either the combined +3.3 and +5 volt line rating or the combined +3.3, +5
and +12 volt line rating. It means the maximum wattage that can be supplied
if those two or three lines were drawn upon simultaneously.
Specification hocus pocus: the good
This is where what isn’t on the label is as important as what is. A manufacturer
should supply the combined rating for the +3.3 and + 5.5 volt line and then
supply the combined rating for the +3.3, +5 and +12 volt line.
combined
220
combined
400
This shows that if the maximum is asked of the +3.3 and +5 volt line simultaneously
then the power supply will deliver a maximum of 220 watts on those lines. Remember
that the demand does not have to be equal on each line. It can be any amount
as long as the total wattage equals 220 watts. For example if a 15 amp draw
is put on the +3.3 line that is a total of 49.5 watts therefore 170.5 watts
remains available on the +5 line which would be a maximum of 34.1 amps. (5 volts
x 34.1 amps = 170.5 watts)
It also shows that if the maximum were asked of the +3.3, +5 and +12 volt lines
then the power supply will deliver a maximum of 400 watts. For purpose of simplified
explanation the same rule of balance applies.
The remaining 20 watts of the 420 watt continuous power rating comes from the
addition of the remaining lines which is 28.5 watts. The manufacturer rounds
it down to 420 watts most likely because a 428.5 watt power supply is an odd
rating to market. It leaves a little margin for error too. This is good information
on a label.
Specification Hocus Pocus: The better
A really handy specification that rarely is included in power supply specifications
is the maximum amperage of the combined lines.
combined
220@30 amps
combined
400@15 amps
Math comes to the rescue again. A power supply could supply 400 watts of power
BUT if it is 1 volt and 400 amps then it quickly changes the picture for a 12
volt device. If a device that requires 30 amps draws upon the combined +3.3/+5/+12
line which is 12 volts then
12 volts x 30 amps = 360 watts
Nearly all of the power supply’s resources have been eaten up by a single device.
This is an extreme scenario but when all the components in a real system are
added up and amperages taken into account the power supply could be less than
adequate for the job. In a nutshell it is the amperage that limits the overall
capability. The simple rule of thumb is that more amperage on the specific line
or combined line is better. It is disappointing that manufacturer’s don’t readily
release this information as it can have a profound effect. Two different power
supplies may both be 400 watts but the if the amperage on the combined lines
is less for one then that PSU may greatly affect system stability.
Specification hocus pocus: the not so good
This power supply manufacturer rates the following example at 460 watts but
notice what is missing.
Amps 35 35 33 1 1 2.2
Watts 115.5 175 396 12 5 11
combined
185
combined
The +3.3 and +5 volt combined rating is supplied but not the +3.3, +5 and +12
volt line combined rating. It cannot safely be assumed that the combined +3.3,
+5 and +12 volt line is approximately 430 watts (460 watt rated power minus
the sum of -12, -5 and +5 VSB line). It cannot be assumed that the manufacturer
is trying to hide a defect. The problem is the information isn’t available to
know.
This is where it is important to look carefully at power supply specifications.
The maximum rated output is known which is 420 watts. This number is usually
very close (within only a few watts) of the sum of the combined +3.3/+5/+12
volt rating and the remaining negative lines therefore some simple math:
420 – (12 + 5 + 11) = 392
392 watts is only an assumed approximation due to missing information but it
is valuable to know. This will become apparent when comparing known values of
the combined +3.3/+5/+12 rating in other power supplies of similar maximum wattages.
Further on in this article it will be shown that the average is around 380-410
for this range which makes the predicted 392 watts believable. Remember it isn’t
verified by the manufacturer so use caution.
What IS important is comparing the individual wattages to the combined totals….either
the combined +3.3/+5 rating or the combined +3.3/+5/+12 rating. The prediction
is for a 392 watt rating on the combined +3.3/+5/+12 volt line which is less
than the individual +12 volt line maximum wattage. Individual maximum wattages
can NEVER exceed the combined totals they are governed by.
This predicted combined +3.3/+5/+12 volt rating and the associated individual
12 volt rating are now suspect. This power supply should be looked upon with
skepticism. THAT is the story that specifications can tell. Be cautious of figures
like those that are too close or over the combined ratings.
We got graph: 23 power supplies compared
The test is that of specifications. 23 power supplies have been grouped into
a 350-360 watt range and 400-470 watt range. All specifications are according
to the manufacturer. Null values indicate that specifications were not available
on the manufacturer’s website. Pricing was determined by lowest price on Pricewatch.com
the date of this article except Channel Well Technology (approximated by nearest
model), Topower (n/a) & PC Power & Cooling (from pcpowerandcooling.com).
Each group is sorted by:
  • +3.3/+5 volt line combined wattage rating
  • +3.3/+5/+12 volt line combined wattage rating
  • +3.3/+5 volt line combined wattage rating as a percentage of maximum rated
    output
  • +3.3/+5/+12 volt line combined wattage rating as a percentage of maximum
    rated output
  • price
  • maximum rated output
350-360 Watt Power Supplies
300_360_2_lines2max
300_360_alllines2max
300_360_2linescombined
300_360_allcombinedmax
300_360_bymaxrated
300_360_byprice
350-360 Watt conclusions
Since 6 of the 8 power supplies were 350 watts and the remaining two were each
360 watts the playing field is fairly even. With the available data only the
Coolmax CX350 fell slightly behind the pack (a mere 4.5 watts) for the maximum
output of all positive lines (+3.3/+5/+12).
The +3.3 and +5 combined lines are the driving force behind the DC power requirements
for GPU and CPU and therefore of greater interest. Surprisingly, considering
Enermax leads the pack as one of the most expensive, it takes last place delivering
185 watts of combined +3.3/+5 DC power.
Antec is the leader turning in 230 watts of +3.3/+5 volt combined. The Antec
SL350 is more expensive than the pack average but not the most expensive. Enhance
challenges with an equal +3.3/+5 combined wattage rating at a few dollars less.
The downfall is that enhance does not supply a combined +3.3/+5/+12 rating.
The Enhance ATX-1136H is rated at 360 watts which means the combined +3.3/+5/+12
rating should be, by extrapolation, approximately 340 watts. This is an unverifiable
figure but if true it puts Enhance in a very good position.
400-470 Watt Power Supplies
400_470_2_lines2max
400_470_all_lines2max
400_470_2linescombined
400_470_allcombinedmax
400_470_bymaxrated
400_470_byprice
400-470 Watt conclusions
Enermax continues to disappoint delivering the least amount of combined +3.3/+5
wattage compared to its higher than average price. This is where specifications
can work for the consumer as it doesn’t always show that “you get what
you pay for.”
PC Power and Cooling turns in the most expensive price tag but with that a
whopping 300 watts on the combined +3.3/+5 volt lines. There is plenty of “oomph”
there but only at a maximum output of 400 watts. Zalman turns in a respectable
235 watts on the +3.3/+5 volt lines and ranks above the price average but well
below the two most expensive power supplies. It caught our eye due to Zalman’s
quiet CPU design. Similarly the Vantec 470 costs only a few dollars more but
packs 70 more watts on the maximum rated wattage while still competing well
with 235 watts on the combined +3.3/+5 lines. Our vote will go to the Vantec
470.
Truth and consequences
In a perfect world there would be a comprehensive database of controlled tests.
Each power supply would undergo the same battery of laboratory tests. Unfortunately
this does not exist and the consumer is faced with choice by price, by popular
recommendation or using a bit of synaptic power.
This test of specifications illustrated what you, the reader, will have hopefully
learned through reading this article. Specifications have to be looked at carefully
in order to narrow down choices. Once those choices have been made then a purchase
can be made or the search for further information is made that much easier.
There are some conclusions that can be made:
  1. A higher efficiency rating percentage number will contribute to a smaller
    energy bill.
  2. A PFC equipped power supply allegedly contributes to a smaller energy bill.
  3. Any one PC component will rarely, if ever, reach its maximum load potential
    and it is a more remote chance that every PC component will reach its maximum
    load potential simultaneously.
  4. Wattage on any given line or combined line should be a minimum of 1.5 times
    the required maximum. More if further expansion is planned. Remember that
    combined line wattage rating overrules the individual ratings they are combining.
  5. More amperage on a given line or combined line is better. Same rule of combination
    as point 4.
  6. More wattage on a given line or combined line is better. Same rule of combination
    as point 4.
  7. Be careful of the difference between the +3.3, +5 and +12 combined rating
    and the power supply rated output. It may say 400 watts but only deliver 350
    on the positive lines where it is needed.
  8. Be suspect of specifications that only supply the +3.3 and +5 volt combined
    rating and not the +3.3, +5 and +12 volt combined rating.
  9. For choosing minimal power supply wattage for normal operation, as a loose
    rule of thumb, the sum of all wattages of all the PC components should be
    multiplied by 1.5 and rounded to the next available power supply rated output.
Power supply tests should be done under laboratory conditions. They should
be carried out with professional testing equipment neither we, nor any other
hardware review site, can or wants to afford. Professional DC load testers and
associated equipment costs thousands and even tens of thousands of dollars.
Short-Media’s real world power supply tests and roundups will feature watt-hour
comparisons and simulated load tests with voltage observations made on each
of the positive lines. It may not be laboratory conditions but it will help
in the decision making process.
The simple answer
Shocking isn’t it? Not every power supply is what it appears to be. Specifications
can and are distorted to provide more shelf appeal. Not every manufacturer is
sleight of hand with their specifications and not every model is a sheep in
wolf’s clothing. So is there a simple answer? No but you want one regardless.
At the time of this article we would say that a power supply with a minimum
of 350 watts would be acceptable but we sure would recommend 400 watts.
But…
Overclockers and enthusiasts everywhere want to squeeze every bit out of their
PC. Look to what setup you have; the “it depends” scenario. Planning
to crank up the voltage on the processor and ram? That 3.3 and 5 volt line better
have sufficient continuous wattage. Looking to RAID four drives together then
a power supply with a higher amperage on the 12 volt line is preferable and
make sure that line has a lot of wattage headroom. Component startup can sometimes
double the demand on the power supply for a short period of time.
For overclockers and enthusiasts the answer isn’t impossible to find. It just
takes a bit more investigation to get there.
  1. mmonnin
    mmonnin Good article. YGPM.
  2. TheSmJ
    TheSmJ Good stuff. This is the wort of thing I wish CompUSA customers would be aware of....
    Those people....
  3. edcentric
    edcentric Nice job MM.
    If the foundation isn't solid the building is no good. The same is true with computers.
    As much as I hate to say it THG has a good review of PSUs up. Typical Tom's fashion they gloss over a few key points. But at least they actually load test the units. None in this batch smoked, but some droped voltage real bad.
  4. Garg
    Garg Excellent article MM! Now I've got to go check the new PSU I just bought and find out if it was a good idea or not :D
  5. Straight_Man
    Straight_Man Good article.
    John.
  6. Unregistered Really Good Article, This is Usefull for Students.
    M.Madasamy.
  7. entropy
    entropy Is it just me or is the link dead?
  8. Gobbles
  9. Jimborae
    Jimborae Houston we have a problem
    dead linkage :)
  10. MediaMan
  11. tjo
    tjo Good article, but the print friendly version is slightly too wide. Chops off a few characters on the right side. Adjusting margins, etc didn't help; had to cut and paste and then muck with the width parameters in HTML to make it print out OK.
  12. Unregistered A PFC equipped power supply may not affect the overall wattage performance but it allegedly makes the power supply more efficient at managing a stage of converting AC into DC and therefore reduce energy costs.
    PFC makes the amps less "peaky," which helps power companies because their wiring has to be capable of carrying the peak amps, and with PFC they can deliver more power without increasing the peak amps. Commercial electric customers are billed according to PF, but, at least in the U.S., residential customers are not, so PFC won't cut their costs. The only benefit PFC gives them is the ability for their UPS to deliver more power (notice they're rated by VA, which is equal to power with a PF of 1). PFC actually reduces efficiency and raises cost of operation a very slight amount.
  13. edcentric
    edcentric MM, I have just gotten around to looking at the Fortron Blue thing.
    There is something fishy about the rating.
    They list 150W for 3.3 + 5. Sounds low.
    and then for 3.3+5+12 they list 440W. It doesn't add up for me.
  14. floppybootstomp
    floppybootstomp Just a small observation. The terms 'positive and negative' are usually used when referring to AC.
    When dealing with DC I've always understood 0V (Nought, or zero, volts) to be the 'negative' with either a plus or minus volts being referenced to it.
    A split rail PSU would be be a twin rail supply with both a plus and a minus volts referenced to 0V.
    Therefore, when considering a minus volts, the 0V (generally referred to as the 'negative') would in fact be the positive.
    Therefore, imo, it's always best to refer to DC voltage as plus volts and 0V or minus volts and 0V, not positive and negative.
  15. MediaMan
    MediaMan
    Welcome to the wonderful world of specifications. It's a challenge at times to determine what the "real" specs are. Try wrapping your head around stereo specs for a change.
    Power Factor...hmmm...hopefully these snippets will help explain.
    WHY IS POWER FACTOR IMPORTANT?
    KVa is total power available to you and what you pay for. The lower the Power Factor, the more KVa is needed. Low Power Factors tend to make system voltage unstable, increase heat in electrical apparatus and can cause failure of electrical equipment. Many utility companies bill you for your poor Power Factor, increasing your cost of electricity. Utility companies have multiple rate schedules, and depending upon your rate schedule, Power Factor penalties may be a separate line item as a demand charge or may be considered as part your general electrical usage.
    And now the marketing doctor's spin
    Power factor correction sharply reduces the demand for reactive current which in turn saves fuel, reduces transmission and transformer losses, improves voltage regulation, and increases available capacity throughout the power company's system without additional investment in generation or distribution. Reducing peak current demand can allow the utility to postpone the construction of new generating capacity.
    And I always said the PFC is best explained mathematically so ...Expand and bend your mind.
  16. EMT
    EMT Neat article. I'm on the middle of page 2 and I disagree with the bottom bit about amps. Suppose the 12V line can put out 20A max (240W). The devices are connected in parallel so they get the same voltage and different currents... then the current delivered by the power supply is the sum of the currents through each of the devices. Note that this means the load is "too much" beyond 20A and beyond 240W (these will always occur at the same time -- you can check for either excessive wattage or amps and one implies the other).
  17. NFL picks <strong>How to handicapp NFL...</strong>
    ...unlike NFL picks. Handicapping and making predictions can be quite fun, but try to check expert......
