A bunch of parts...Now what?
Just bought a Thermaltake Armor case, AMD 2G processor, 600W power supply, an MSI VGA, ASUS MB and 1Gig of matched memory. This is my first build so i'm a little overwhelmed. The PSU is in the case, and the VGA, processor and RAM are on the MB. I plugged in the system power from both the front switch and PSU, the reset button, internal speaker and led's. Two USB 2.0 inputs from the top of the case are plugged in on the MB too. The writing on the connectors is facing the top of the case. there seems to a lot of wires coming out of the PSU that don't have spots on the MB. Just to start: What are the clunky, white 4 pin connectors? How do I do the audio and IEEE 1394?
Also, the SATA connectors from the PSU dont fit the SATA on the MB. OK, I admit I don't know what SATA is.....
Sata power cable to HDD.
Sata comm cable from Mobo to HDD.
so if you look at the back of the drive it should look like this:
if you have a more modern SATA drive, the power connector is the SATA connector you've already stated you have coming from your PSU and the data connector looks like this:
so the back of the drive should look like this:
if you tell me which kind of drive you have I can tell you what to plug in where.
Does it matter which Molex connector gets hooked up to a drive?
There is a small wire (twisted black and white) attached to a ground point in the case that is marked MICRO SW. What is this and where does it go on the board?
Those connectors hardly ever match up between case / motherboard. From what you have I'd guess at these....but it is only a guess:
Ear L -> BLINE OUT L
Ear R -> BLINEOUT R
Mic In -> MIC2
Mic VCC -> MIC PWR
ground -> AGND
that leaves Return L & R to go in NC and +5A (is that +5V?) but I'm not sure if those actually go in there...
in any case, those connectors are just for the front panel connectors on the case yes? You should actually have in / ouputs on the back of the case, those front panel ones are just there for convenience, I never connect those up.
nope.
no idea. Again, if I had to guess I'd say it's a chassis intrusion detection switch. Some motherboards let you plug something into them that tells you if the case has been opened since last time you booted the PC. Check near the 'ground point' the cable comes from. Is it connected to a little switch that's near one of the edges of your case?
Other than that, everything is hooked up but the CPU fan/heatsink because I dont have any thermal paste. I'll try to get some tomorrow so I can fire it up.
Actually, can I run it without the paste for a short period to set up BIOS without hurting anything?
Did the HS/F come with the CPU? If so, there should be a square piece of sticky stuff already attached to the HS. This is not as good as a quality thermal paste, but should work fine in the short term.
You don't want to use them both at the same time, though. If you decide to add the paste later make sure you carefully (don't scratch them!) remove all of the sticky stuff from both the HS and the CPU first.
The small three-pin connector should fit on the MB in any spare fan header you find. If there is only one wire leading to the connection you will need to do the old Molex job on it, too. (The fact that there is but a single wire means that the MB connection is for RPM monitoring only.)
The big advantage to this is that the third wire allows you to monitor the fans RPM.
There's a guide to repair installations here: Linky
EDIT: Deicist was way too quick for me.
Dragon, the second HDD has most of my stuff on it. I try to keep the C as just the OS.
The only thing I can get into is the BIOS setup utility.
I have not bothered to istall th 3.5" floppy drive, do i need that to update the BIOS? Could that be the problem?
Are you sure your CD drive works? does the light come on the front of the drive to show it's seeking? is it showing as detected in the BIOS?
The BIOS shows the 2 HDDs but thats it. I can get to the screen with "Phoenix-Award BIOS v6.00" etc. Lists the MB, CPU, the master and slave drives. Below that, it says "Floppy disk fail (40)".
If I press F1 after this, I get a "Disk Boot Failure, Insert system disk and press enter"
Now I get a screen with the PCI Device listing.....
Is there a way I can enter BIOS once windows is running? Through DOS maybe? right now the only way i can boot up the machine is with thw windows disk in the CDROM drive.
What would make my KB do that? It was working fine before.
Once I do get in how do i enable that?
Please pardon the ignorance....
