help!! Radeon 9800 Pro Too Hot?
Hi,
I beleive my computer hardware problem is my graphics card
radaeon 9800 pro,
latest drivers and such, but when i play games .
warcraft 3, cs source, tribes vegeance etc, it freezes and i gotta reboot!
this occours from time to time,
ive installed 3 new fans over the last 2 days and still get the same problem ,
im sorta a noob on computers so if u use really technical stuff i really wont know what ur on about,
reason why i think its the heat is cause when i put a normal fan used for humans next to the computer with the case open, it doesnt happen at all, also it reaches around 72 degrees when playing games otherwise averagely its around 50 degrees, donno if thats normal at all
really need help on this!
ive enclosed a diagram of my computer and where the fans are incase that helps
and my specs
512 ream
120hdd
2.6ghz
p4
radaeon 9800 pro,
and my specs
512 ream
120hdd
2.6ghz
p4
If your CPU is reaching 70 degree temps then start worrying. What sort of case temps are you getting? More fans is sometimes counter productive.
also, ive come to learn that my grapics card is overclocked
ull all probly no what that means so the best solution would be make it back to normal or under clock it right?
hjow do i do this?
72C is pretty hot for a GPU unless your running a 6800 Ultra. The average GPU temp across all ships is around 52C with 65 to 68C under full load.
First off welcome to Short-Media.com
Now if you put your hand over the back of the PC do you feel warm aitr blowing out? also just to check the entire PC are all port fans working along with your CPU fan?
To underclock an ATI 9800 Pro just run ATI Tools. you should see options for core speed. If my memory servers me correctly the stock core speed is 325MHz give that a try and see if it runs a bit cooler
How much thermal paste did you use? You shouldn't need more then about a grain of rice or half a BB worth, spread on a thin layer across the top of the GPU (use an old credit card or razor blade).
If its not overclocked...that card should be around 60C (+/- 2C) at full load. How fast is your GPU fan spinning? If you have a sticky fan, it may look like its spinning but it could be really slow.
hope thats not a problem!!
and thanks for everyones replies and help but the problem has been resolved, i restored factory settings of the video card! and everything seems fine
The instructions I've linked apply to graphics chips, CPUs, motherboard northbridges and southbridges - essentially any flat chip that uses a heatsink.
is it nesescary to take it off and re do it
also
i thought i fixed the problem
but
it just restarted again during my game!!
any suggestions?
when i put a fan against it, a human cooling fan, it works fine
Or, you could leave the case side off and the ventilation fan running. Your choice.
http://ryzom.com/forum/showthread.php?t=16299&page=3&pp=10
and this guy has the same problem as me,
he stated his solution was he uninstalled games and drivers and reinstalled them,
i think this sounds too simple to be a solution? what do u guys think ? if its aworth a try ill do it
keep in mind the games were installed when my video card was over clocked into a 9800 PRO when its REALLY a 9800 !
now its a 9800! as normal default,
feedback please!
i think ill change the silver greese as u said though,
There are more issues in that pic than just too much paste...
not the games??
hmm,,
well
when i flashed the video card to make it back to normal and not overclocked, those were deleted i beleive and as i restarted comp it detected new hardware(video card) then i re downloaded the drivers
so im not sure?
do it or not?
Delete all your video card drivers! unistall the Control panel, the drivers anything that is ATI unistall it.
Restart the comp when finished.
Now install the new drivers. if at all possible make sure all your games have the latest patches as well. Some my contain bug issue fixes that might have been causing temps to rise.
Looks pretty good so long as he was using phase cooling
Sledgehammer: He didn't forget. He put on too much, and needs to clean it and reapply.
kc-ok-la: Did you do that yet?
where do i buy it from
and also,
is this likely to be the problem?
i got a tube with the fan i put in , and i used like almost the entire thing because i didnt no what to do with it and assumed 1 fan 1 needle thing for it so use it lol
wish i kept it,
Use the link provided on page one for guidance on how to reapply it properly.
You can buy thermal paste from any computer store, I'd recommend the "Arctic Silver" brand. If stores fail you, visit newegg.com.
