Monitor trouble, need help :'( :'(
I got an Iiyama Vision Master Pro 413 around a year ago and the monitor was really great untill something must have happened to it. Its really sensitive so if u touch it or if the sounds too loud the screen vibrates but now all the colors go screewy whenever I turn it on and I have to degauss it like 20 times before it's corrected. Now its gotten totaly messed up, the colors in the bottom right are all totally yellow
The problem is I don't have the reciet left so no warranty. The monitor cost me 500 euros when I bought it and now its screwed
any help would be appriciated
thanks in advance!
thanks in advance! 0
You should bring it in a repair shop.
I recomend you get that fixed though..
mD
The reason that magnets screw things up in monitors (not that you care or anything) is that the electron gun shoots electrons and an electromagnet adjusts its power level to bend the electron so that it hits the right set of colors (to make up a single pixel, and then the process gets repeated a lot, very fast) and the right pixel. Magnets throw off this electromagnetic exactness and cause the monitor to 'misfire' and hit the incorrect color or perhaps not hit at all.
Enough with the science lesson....
NS
Just get the shit away and slap it a few times (actually does help, but dont give it a pussy slap nor a burly slap...just enough to where you see some results :P), run the degausser in the montiors OSD as many times as you can stand.
The monitor isnt permanently damaged if thats what you are wondering, its just somewhat fucked for the moment. Not that time will change this though...
Professional Degauss is the key, it doesnt cost much either. I dont know where to do it...maybe a TV Repair Shop.
Turn the monitor upside down, attach desk upside down to celing, attach chair midified with harness to celing, place upside down computer on upside down desk.
Problem solved
mD
