External Hard Drive Problem
Hello, I've got a Maxtor 120GB, 8MB and an external firewire enclosure which I use to connect the hard drive to my laptop. The hard drive worked just fine yesterday but now I can't even access it. I don't know why is that. I can see the LED showing some activity but then when I double click the letter for this drive in "My computer", I get errors like "the parameter is not correct" and "the hard drive is corrupted". I don't think that I did anything wrong.. this is very strange.. Please help cause I can't lose all my data just like that.
btw, can you see anything noteworthy related to the jumper settings ?
my jumper settings seem to be at (cable select), is that OK ?
One thing, please do not use a removable or external firewire device to boot from, this is very risky. Use a removable or external to store data on but not to boot from. To have firewire up and access storage devices through it, you usually need Windows or an O\S that can access firewire to be up first. Or you get junk on HD and not good file system structure. With special programs helping the booting has been done, but they(the helping programs or special O\S modules that run at DOS level) need to be specific to the external device holding the drive also for this to work right.
ADDED, beacause of what the thread starter said and did not say:
If HD has valid data and firewire cannot get to it or firewire support is not present and the HD therefore cannot be found and accessed, the easiest fix is to mount drive as slave in computer and copy data over to the boot drive(with boot drive set to master with jumper) with an imaging program. Simply changing how HD is findable might help get data off it, a LOT. Hooking HD up to motherboard directly as an IDE drive or as what it is without the external adapter and cable to it can help accomplish that.
John D.
http://www.acortech.com/.sc/ms/cat/1032987946/9/nc/External%20Enclosure
It's near the end (mine only has a firewire connection though) :
BYTEC 3.5" EXTERNAL FIREWIRE+USB2.0 COMBO ENCLOSURE ME720U2F
3.5" EXTERNAL FIREWIRE + USB2.0 COMBO ENCLOSURE ME720U2F
Our Price $59
My Maxtor model is: DiamondMax Plus 9 120GB ATA/133 HDD, 6Y120PO
My friend has exactly the same configuration as I do and he doesn't have any problems. strange..
I bought it from that guy
I restarted my system while having the enclosure powered on and ScanDISK was automatically launched to check for any errors on the hard drive F. At that poing I got an "unknown error occured" and I was redirected to windows welcoming screen. Then I chosen to have scandisk scan for the drive again and I restarted my system. At this point scandisk reported some fixes of bad clusters and now I'm able to access my data. And the good thing is that nothing was lost I believe. Does anybody know where I can find the log file of the fixes that scandisk did ??
Don't feel bad. I do that all the time!
